Wittson Custom Ti Cycles- Mtbr.com
Results 1 to 11 of 11
    Jan 2018
    Hey all! My name is Mindaugas and I am the framebuilder at Wittson Custom Ti Cycles. I decided to create this thread to share with you our most interesting projects.
    I'll start with our Wittson Custom 29er Plus 137 project
    Wittson Custom Ti Cycles-titanium_29er_plus_frame_with_sliding_dropouts_01.jpg
    Wittson Custom Ti Cycles-titanium_29er_plus_frame_with_sliding_dropouts_02.jpg
    Wittson Custom Ti Cycles-titanium_29er_plus_frame_with_sliding_dropouts_03.jpg
    Wittson Custom Ti Cycles-titanium_29er_plus_frame_with_sliding_dropouts_04.jpg
    Wittson Custom Ti Cycles-titanium_29er_plus_frame_with_sliding_dropouts_07.jpg
    Wittson Custom Ti Cycles-titanium_29er_plus_frame_with_sliding_dropouts_08.jpg
    Wittson Custom Ti Cycles-titanium_29er_plus_frame_with_sliding_dropouts_09.jpg
    Wittson Custom Ti Cycles-titanium_29er_plus_frame_with_sliding_dropouts_11.jpg
    Wittson Custom Ti Cycles-titanium_29er_plus_frame_with_sliding_dropouts_14.jpg
    - mini triple triangle design
    - 29er plus geometry
    - oversized externally and internally butted headtube for conical 1.5" fork
    - support gusset bottom of downtube
    - double butted curved seattube
    - hydroformed seatstays
    - curved seatstay bridge
    - hydroformed chainstays with ti plate
    - triple zip-tie cable routing
    - BSA bottom bracket
    - made in USA PARAGON flat sliding dropouts with DT Swiss 142 x 12mm postmount inserts
    - hand brushed finish
    - custom sandblasting
    - anodized bolts
    Size: Medium (435x599mm)
    Weight: 1790g
    Reputation: Just J's Avatar
    Feb 2005
    That looks really good, thanks for sharing and welcome to the forum.
    Jan 2018
    Quote Originally Posted by Just J View Post
    cheers pal!
    Jan 2018
    Wittson Cross Country 29er Bestia Boost 159
    This beast is now shredding the hills, forests and country roads of Hungary. One of the sickest complete builds we've ever done.
    Jan 2018
    Ti+Carbon anyone?
    Wittson Custom XC 29er 014
    - custom cross country race geometry
    - oversized internally butted headtube for conical 1.5" fork
    - made in Italy DEDACCIAI carbon shaped toptube
    - made in Italy DEDACCIAI carbon conical downtube
    - integrated seatpost with an support on toptube/seatsatays cross section
    - ti seatmast with ti bolts
    - integrated disc cable routing
    - integrated shifting cable routing
    - PressFit BB92 bottom bracket
    - custom CNC’ed dropouts
    - custom paint scheme
    - ti headbadge
    - ti bolts
    Size: Large (425x620mm)
    Weight: 1630g (seattube uncut)
    Reputation: LyNx's Avatar
    Very nice, welds look very even and clean. What sort of cost (US dollars) are you talking for a complete frameset? Can you explain why you did the seatstays to the top tube instead of the seat tube?
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Jan 2018
    Price including our titanium fork, Chris King headset and Thomson seatpost clamp is 4199 USD. Price without the fork would drop to 3279 USD.
    The mini trip triangle design has more to do with aesthetics than ride quality. It does make the frame tiny bit stiffer, but not significantly.
    cmg
    cmg is online now
    passed out in your garden
    Reputation: cmg's Avatar
    Mar 2012
    those frames/bikes make my pants go tight
    always mad and usually drunk......
    Thanks for the quick reply, was just curious and to be honest, have to say I did not expect you to be more than other well known US based custom builders. A rigid Ti is still my dream bike, at some point I'll be able to afford one, but right now, sadly, it's not in the books, will most likely stick to steel for the new while.
    Quote Originally Posted by Mindaugasz View Post
    Thanks! Price including our titanium fork, Chris King headset and Thomson seatpost clamp is 4199 USD. Price without the fork would drop to 3279 USD.
    Jan 2018
    Correct me if I am wrong but I don't know of any US framebuilder who would offer a CUSTOM build including titanium fork below 4k. Not the ones who actually build their frames in US
    Jan 2018
    Gravel grinder anyone?
    WITTSON X BLACKSMITH CYCLE CUSTOM GRAVEL PROJECT
    - custom gravel geometry
    - oversized externally and internally butted headtube for conical 1.25" fork
    - made in Italy DEDACCIAI carbon quadrangular toptube
    - made in Italy DEDACCIAI carbon quadrangular downtube
    - double butted seattube
    - shallow hydroformed seatstays
    - PressFit 30 bottom bracket
    - flat disc mount
    - made in USA PARAGON dropouts compatible with both DT Swiss 142 x 12mm and SHIMANO 142 x 12mm hangers
    - DT Swiss 142 x 12mm thru axle removable alu hanger
    Weight: 1440g
    Framebuilder at Wittson Custom Ti Cycles
  1. Replies: 2
    Last Post: 07-09-2016, 08:12 PM
  2. Replies: 2
    Last Post: 07-09-2016, 08:11 PM
  3. Replies: 1
    Last Post: 07-06-2016, 09:05 AM
  4. Replies: 1
    Last Post: 07-06-2016, 08:58 AM
  5. Replies: 6
    Last Post: 03-21-2014, 10:06 AM
