Wittson Custom Ti Cycles
Printable View
  • 01-03-2018
    Mindaugasz
    9 Attachment(s)
    Hey all! My name is Mindaugas and I am the framebuilder at Wittson Custom Ti Cycles. I decided to create this thread to share with you our most interesting projects.
    I'll start with our Wittson Custom 29er Plus 137 project
    Attachment 1176024
    Attachment 1176025
    Attachment 1176026
    Attachment 1176027
    Attachment 1176028
    Attachment 1176029
    Attachment 1176030
    Attachment 1176031
    Attachment 1176032
    - mini triple triangle design
    - 29er plus geometry
    - oversized externally and internally butted headtube for conical 1.5" fork
    - support gusset bottom of downtube
    - double butted curved seattube
    - hydroformed seatstays
    - curved seatstay bridge
    - hydroformed chainstays with ti plate
    - triple zip-tie cable routing
    - BSA bottom bracket
    - made in USA PARAGON flat sliding dropouts with DT Swiss 142 x 12mm postmount inserts
    - hand brushed finish
    - custom sandblasting
    - anodized bolts
    Size: Medium (435x599mm)
    Weight: 1790g
  • 01-04-2018
    Just J
    That looks really good, thanks for sharing and welcome to the forum. :)
  • 01-04-2018
    Mindaugasz
    cheers pal!
  • 01-06-2018
    Mindaugasz
    Wittson Cross Country 29er Bestia Boost 159
    This beast is now shredding the hills, forests and country roads of Hungary. One of the sickest complete builds we've ever done.
  • 01-12-2018
    Mindaugasz
    6 Attachment(s)
    Ti+Carbon anyone? ;)
    Wittson Custom XC 29er 014
    Attachment 1177619
    Attachment 1177620
    Attachment 1177621
    Attachment 1177622
    Attachment 1177623
    Attachment 1177624
    - custom cross country race geometry
    - oversized internally butted headtube for conical 1.5" fork
    - made in Italy DEDACCIAI carbon shaped toptube
    - made in Italy DEDACCIAI carbon conical downtube
    - integrated seatpost with an support on toptube/seatsatays cross section
    - ti seatmast with ti bolts
    - integrated disc cable routing
    - integrated shifting cable routing
    - PressFit BB92 bottom bracket
    - custom CNC’ed dropouts
    - custom paint scheme
    - ti headbadge
    - ti bolts
    Size: Large (425x620mm)
    Weight: 1630g (seattube uncut)
  • 01-12-2018
    LyNx
    Very nice, welds look very even and clean. What sort of cost (US dollars) are you talking for a complete frameset? Can you explain why you did the seatstays to the top tube instead of the seat tube?
  • 01-12-2018
    Mindaugasz
    Price including our titanium fork, Chris King headset and Thomson seatpost clamp is 4199 USD. Price without the fork would drop to 3279 USD.
    The mini trip triangle design has more to do with aesthetics than ride quality. It does make the frame tiny bit stiffer, but not significantly.
  • 01-12-2018
    cmg
    those frames/bikes make my pants go tight
    :thumbsup:
  • 01-12-2018
    LyNx
    Thanks for the quick reply, was just curious and to be honest, have to say I did not expect you to be more than other well known US based custom builders. A rigid Ti is still my dream bike, at some point I'll be able to afford one, but right now, sadly, it's not in the books, will most likely stick to steel for the new while.
    Originally Posted by Mindaugasz View Post
    Thanks! Price including our titanium fork, Chris King headset and Thomson seatpost clamp is 4199 USD. Price without the fork would drop to 3279 USD.
  • 01-12-2018
    Mindaugasz
    Correct me if I am wrong but I don't know of any US framebuilder who would offer a CUSTOM build including titanium fork below 4k. Not the ones who actually build their frames in US :)
  • 01-24-2018
    Mindaugasz
    6 Attachment(s)
    Gravel grinder anyone? :cool:
    Attachment 1179611
    Attachment 1179613
    Attachment 1179614
    Attachment 1179615
    Attachment 1179616
    Attachment 1179617
    WITTSON X BLACKSMITH CYCLE CUSTOM GRAVEL PROJECT
    - custom gravel geometry
    - oversized externally and internally butted headtube for conical 1.25" fork
    - made in Italy DEDACCIAI carbon quadrangular toptube
    - made in Italy DEDACCIAI carbon quadrangular downtube
    - double butted seattube
    - shallow hydroformed seatstays
    - PressFit 30 bottom bracket
    - flat disc mount
    - made in USA PARAGON dropouts compatible with both DT Swiss 142 x 12mm and SHIMANO 142 x 12mm hangers
    - DT Swiss 142 x 12mm thru axle removable alu hanger
    Weight: 1440g
