What kind of Ti do they (black sheep, desalvo) use?- Mtbr.com
Results 1 to 5 of 5
    Do you know what kind of Ti tubing Black Sheep, DeSalvo, Jones .... use to build their bikes? They use 6AL-4V?
    In FTF We Trust
    Reputation: el-cid's Avatar
    I doubt that there are any small/custom builders that build with 6AL/4V since it has to be rolled (then seam welded) into tubes and can't be extruded. Most builders use 3AL/2.5V for all main tubes and 6/4 for dropouts and maybe some other small parts. The big difference would be whether you choose straight gauge or butted tubes.
    "I'll disintegrate over time if I expect my body to try to keep up with my mind" -BM
    Race, Rocks or Road...Just Ride
    Dec 2005
    along with that the 6/4 tubes are very expensive. Moots has decided to stop using 6/4 for tubes due to the cost and availability along with there is little weight savings (in the grand scheme) in comparison to butted 3/2 tubes.
    Reputation: Thylacine's Avatar
    We all use 3-2.5 Ti. Reynolds has a 6-4 tubeset available, but it's only really road friendly. It's also five times the price of PG 3-2.5 so in some ways the cost/performance curve is a bit steep on that one.
    Still, it is twice as strong as 3-2.5, so for someone interested in having the final word in titanium road frame construction, I guess it's the way to go.
    No longer member of the bike industry nor society, so don't hassle me.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    You also can find some brands that'll use commercially pure grade 4 titanium (which is as strong as your basic 4130 CrMo steel, so take a plain 4130 bike, duplicate it exactly in CP Grade 4 and you end up with the same strength at 2/3 the weight basically) and some russian manufacturers use this as well as another alloy like their Ti 5/2 (which is 5% Aluminium and 2% Manganese) which falls between US Ti 3-2.5 and Ti 6-4 for strength.
    I don't post to generate business for myself or make like I'm better than sliced bread
