Voodoo Dambala front derailleur clamp size?
Hi all,
I have a 2009 18" voodoo dambala. I'm planning on doing a 1x9 setup on it, and need to order a N Stop guide for it. What size do I need, I can't seem to find the seat tube diameter on voodoo's website.
I think a 30 should work fine. You can always shim it if you got an n-gear that's too wide for it (that's what I did).
good luck and post pics!!!
I ended up getting their 29mm one, worked like a charm!
Here's a photo of the bike. The setup works great!
neat! is that a 34T chainring?
Good eye! It's a 34 tooth BBG bash ring, with a 32T chain ring behind it.
- You may not post replies
- You may not edit your posts
Forum Rules
