suggestions on sanding sandblasted alum frame- Mtbr.com
Results 1 to 2 of 2
    Reputation: signalMTB's Avatar
    I've got a aluminum frame I just got it back from the sandblasting. It's a lot rougher than I thought it would be. Any suggestions on power drill sanding accessories I can use to finely sand then polish it?
    was plastic bead used or glass?? Ive done 2 frames and used plastic at about 50/60 psi. Glass as low as the blaster will go ONLY to remove corrosion. If it is too rough I would try like 1000 grit sand paper or maybe even red scotchbrite.
