Page 6 of 6 FirstFirst ... 23456
Results 501 to 565 of 565
  1. #501
    May 2018
    New question here.
    Hi! Hope I'm not hijacking the thread. I'm looking for a frameset. Wolverine ticks all the boxes, but the reach is a bit long for me (long legs, short torso). Has anybody found a close alternative to the Wolverine?
    More on what I'm looking for here.
  2. #502
    Aug 2014
    Looked at your post with your ideal bike requirements... Wolverine comes pretty close. I normally ride a 56, and went with a 54 based on top tube length for - happy I did because I'm using a 70mm stem. Maybe look at a 58 with a short stem? I was a little skeptical at first, and I even flamed SOMA a little here and there for strange geo, but now that I am used to it, I actually really like it.
    Mine seems to handle better with a shorter stem anyway, BTW.
    Quote Originally Posted by not_hip View Post
    Sent from my SM-N950U using Tapatalk
  3. #503
    Aug 2014
    Also, for what it's worth, I measured my frame's stack and reach, and they were both longer than the site said they should be... A 54 is spec'd as 395/566 reach/stack, but mine measured 408/573. Granted, I am pretty unsophisticated without fancy tools for this, but I think it's weird that I came up with that much of a difference -especially since I have measured other bikes with given geo and come within a mm or 2 of published specs.
    Quote Originally Posted by SpeedyStein View Post
  4. #504
    May 2018
    Well, that makes things even more complicated. If only I could test ride these things. No dealers in my country though.
    I run a 80 mm 35 degree stem on my bike that has a 390 mm reach.
    The Soma Saga actually looks quite good. Too bad there is no size between the 61 cm (which has a 585 mm seat post) and the 66 cm (which has a 645 mm seat post). Reach on the 66 cm model is even lower than the 62 cm Wolverine (403 mm for the Saga vs 412 mm for the Wolverine). Not quite sure I'm up to the 89.5 cm (with 45 mm tires) standover height though. Inseam is between 91.5 cm and 93.5 cm depending on how far up I press the the book. I'm 187 cm tall. If frames are actually larger than specs on their site, I'm toast.
    The 58 cm Wolverine will put me in the same seatpost in the sky situation as I am now.
    Perhaps I should just copy the Wolverine geo, shorten the top tube and send the thing over to Waltly.
  5. #505
    Aug 2014
    One thing to keep in mind too is head tube length - the Wolverine has a pretty short headtube. They really are long and low bikes. Maybe check out the Double Cross? The new model can take 45mm tires, probably without fenders though. The reach is a fair bit shorter, and the headtube is a bit longer than the Wolverine. Might actually be almost exactly what you are after.
    I've been thinking about building up a Double Cross myself, as a fast all-roader, using WTB Resolutes in 700x42, then committing my Wolverine to commuter duty. Unfortunately, cash is a little low for new bikes at the moment, so it will have to wait.
  6. #506
    two questions for you guys.
    Does anyone know if the 15TA fork holes as large of a tire as the QR fork? I'd like to run a large volume mtb tire for some trips.
    Also, anyone running a flat bar/ jones bar? How much longer of a stem did you need to get the right fit?
    Feb 2017
    I have a Maxxis 2.2 on the front/rear. Rear is maxed out but I think I could fit a 2.4 up front
  8. #508
    with which fork!?
  9. #509
    Feb 2017
    Wolverine thru axle fork
  10. #510
    Quote Originally Posted by bkinsman View Post
    Sweet!
    I'm torn on the functionality of thru-axle for the aesthetics of the crown fork.
  11. #511
    Feb 2017
    Im on mobile so canít post a pic but hereís mine on instagram. Got a rando rack and tara tubus connected to the mid fork eyelet https://instagram.com/p/BjoG58qBPVJ/
  12. #512
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by blantonator View Post
    Sweet!
    I went for the lugged crown fork for aesthetics. I have a 2.1" Racing Ralph on a Stans Arch MK3 rim. It doesn't rub but I wouldn't put a bigger tire in there.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
  13. #513
    Reputation: seat_boy's Avatar
    In the description of the through axle fork, Soma says the tire clearance is tighter than the lugged fork.
    http://www.bikingtoplay.blogspot.com/
    RIGID, not "ridged" or "ridgid"
    PEDAL, not "peddle." Unless you're selling stuff
  14. #514
    Reputation: Psycho1's Avatar
    Aug 2014
    What tires are those?
    Sent from my LG-H872 using Tapatalk
  15. #515
    Aug 2014
    Quote Originally Posted by Psycho1 View Post
    Those look like Ardent Race. Great all around tire, from what I hear.
    If you are trying to decide thru-axle vs qr fork, just go thru axle. It wasn't available when I got my bike, and I have always wished it was, and now I am trying to justify buying the thru axle fork, thru axle sliders, and a new wheelset vs just buying a whole new bike.
  16. #516
    Aug 2014
    I ran a flat bar for a little while - I used a 100mm stem, and use 70mm with my current drop bars. It was ok, but not ideal, a 110 would have probably been better for me. Sometimes you just gotta try a couple though, and find what works for you.
    The bigger issue was the large tires I had on then - 29x2.2 made the bike feel super sluggish with the sliders all the way back.
  17. #517
    Reputation: kyttyra's Avatar
    Mar 2012
    As of yet, my V2 hasn't cracked yet (knocks on wood):
  18. #518
    Aug 2014
    Mine did yesterday
  19. #519
    A God Without A Name
    Reputation: Agwan's Avatar
    Cool. Time for a warranty. The V.3 resolves this and a lot of other issues the early Wolverines have. I was really disappointed in my V1. It was not the quality I had come to expect.
    Sent from my LG-LS993 using Tapatalk
  20. #520
    Aug 2014
    Quote Originally Posted by Agwan View Post
    I've really loved mine. Really bummed. What other improvements were made?. I just wish they had orange still.
  21. #521
    Better paint. E coated internally. Tighter tolerances at the bb, seat and headtubes.
  22. #522
    Aug 2014
    Just the e coat is a worthy upgrade. Wow
  23. #523
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    I acquired a 58 cm clincher version of the Wolverine a few months ago and click off 35mi round trip work commutes on it a couple times a week (with some MTB trail options can C&O canal tow path gravel along the way).
    Running tubeless 1.8" Slant 6 pros at the moment and plan on going with Thunder Burt 2.0's to eke out a bit move volume/cush and lower rolling resistance. Is anyone running ~2.1" tires or is that pushing one's luck? I have a few Niner branded Racing Ralph 2.25's that are really 2.1's and thought of maybe trying them. (I run Racing Ralph 2.25's and 2.35/2.4's on a herd of different 29er's with great success).
    【ツ】 eDub 【ツ】
  24. #524
    Mar 2013
    Anyone's frame crack out of warranty? Are you just SOL at that point? My v1 is still doing okay, but I've only got a month of warranty left. Makes me a little nervous.
  25. #525
    Quote Originally Posted by formula4speed View Post
    Jim Porter has repeatedly stated that he will warranty this specific issue beyond the standard warranty period. Just reach out to him on Facebook. It seems to have a faster turn around than the Soma email.
  26. #526
    Mar 2013
    Cool, that makes me feel a bit better. I'm cautiously optimistic I'll be okay, I'm pretty light at 150 pounds and I don't really hit singletrack with my Wolverine, only pavement and gravel. I do really like the ride quality so I hope it holds up for me.
  27. #527
    Reputation: objectuser's Avatar
    Oct 2013
    I've been contemplating a Wolverine build. This has been a very useful thread. I haven't built a bike since I was racing BMX as a kid. This is definitely more complicated!
    My goal for this build is a comfortable and fun road bike, something I can ride in the city on crappy streets, on paved trails, in flat areas and in the mountains. I don't plan to take it off road, I have a mountain bike for that. I don't even know that the Soma Wolverine is my best steel frame option, but it sparked my interest.
    I've been investigating both a 700c and 650b build.
    650b: The availability of viable tires seems limited. It seems like everyone is running one of the two WTB 650b tires. These do seem like very good tires, though, large, tubeless compatible and 535g. Would be nice to have more options though, that are at least the min 47 width Soma specifies. Anyone have interesting options here?
    I've found a few wheel options, each with their own limitation (either axle, cassette speeds, disc, weight or cost). Trying to find wheels has definitely been an exercise in learning, refinement, iteration and prioritization.
    700c: Some better wheel options here, light enough, not too expensive, gearing options ... There's good reason to favor 700c due to a wider range of available options.
    I have been surprised at the weight of larger 700c tires I've found. I think I'm looking at the wrong stuff ... but the weight seems to be in the 800-1000g range. But maybe I'm looking at too large a size (~45c). My current bike is 700x47 (Conti Comfort Contact) and those tires are pretty heavy. I'll continue looking.
    Either way, I've been all over the map on drivetrain (Tiagra, 105, Rival?), brakes (hydraulic, TRP Spyre?) and various components (no idea how to choose a stem, drop bars, seat post).
    It's been pretty interesting (re-)learning about building a bike.
  28. #528
    Aug 2014
    Quote Originally Posted by objectuser View Post
    If you aren't planning on taking it off road, you might check out the SOMA Fog Cutter. Similar geo, carbon fork painted to match the frame, regular road QR axles with regular dropouts, and similar tube set. If singlespeed-ability isn't a concern, this might make a winner.
    That said, the Wolverine is pretty fantastic, and you won't be wrong for getting one. Being able to fit huge tires is nice. The Wolverine will swallow 29x2.2 tires if you want it to. Single speed is an option; belt drive, 1x, 2x, 3x, or whatever you want to build it up with is cool too. Want thru-axles? Get the unicrown thru axle fork and some sliders from Paragon and you are in business. Want fenders? It has tabs for those. Want a rack? It can do those too, front and back, and at the same time as fenders. Versatile is an understatement with this bike. It does everything, and doesn't look like a Surly with too many bolts/holes in nonsensical places.
    In the 650b/700c debate, there are pros/cons with each, as you already stated. I like 700c for the reasons you stated above - easier to find wheels appropriate for the application, tires are also easy to find, and I prefer more roll-over ability. Plus, the geo of this bike was designed with 700c in mind, and BB height is perfect for me with 700x40 or so tires. Tires that large are going to be heavier than their skinnier counterparts, its just the nature of the beast, but a lot of the tubeless gravel tires have light casings, which do help with the weight - at the price of durability. The WTB Resolutes are pretty much the perfect tire for me with this bike - fast, not terribly heavy, traction everywhere, seem to be lasting well enough, and I think they look fantastic on the orange frame.
    For kit/cockpit, that is all personal choice. I like my bar end shifter with 1x11, but horses for course, you know. I didn't really see any better alternatives that I could afford when I built mine up. This will get some flame, but I suggest avoiding TRP Spyres. They are much better in theory than in practice. I have Spyres now and will be switching to hydros of some sort in the near future. If you want cable discs, get BB7s or Shimano CX77, or better yet, just go hydraulic.
    Overall, though, my Wolverine is my favorite bike, because it rides soooo smoothly, over any terrain. It has taken me on some great rides over lots of different terrain, and I am always glad I rode it at the end. Its not a perfect road bike, and its definitely not a perfect trail bike, but it does strike an excellent balance of go-anywhere and do it quickly. You can't go wrong with a Wolverine.
  29. #529
    Oct 2013
    @SpeedyStein Thanks for the reply!
    Funny, soon after I posted above, I started looking at the Fog Cutter. That's now my target frame, but I'm still very open to something else. I'm also interested in the 2018 Kona Rove ST, but I don't know how the quality compares or if I could even find one. I love the 2018 color, not so much the 2019 color.
    Anyway, currently focused on the Fog Cutter, so your comment indicates I'm headed in the right direction.
    I rode a couple bikes with TRP Spyres and thought they were good. But I've not rode them in anger. They might be more appropriate to road biking vs. trail biking. But that's just a guess.
    I've read that 650b wheels with larger tires, like the WTB Byway has a similar radius as a 700x30 tire. So not as big as a 700x40 but still pretty good.
  30. #530
    Aug 2014
    Haha, great minds think alike! I am eyeing a Fog Cutter over for myself, actually. Will definitely have to save up some pennies, but would love one with Shimano hydraulic 11 speed group, 32mm tubeless tires mounted up to some A23s or similar. Would make a really nice long ride day bike, or a fun and fast bike to take the long way home on my commute.
    I don't like my Spyres because they require so much more adjustment than single piston calipers - it seems like every other time I ride my Wolverine I am adjusting the damn brakes. The sweet spot is pretty narrow, and once you are out of it, they just don't have any power.
    Tire and wheel size is totally a personal choice, but be mindful that the Wolverine has a pretty low bottom bracket already. Most of the folks running 650b rubber on Wolverines are running big rubber - 2.1 or so. But, there are certainly others running byways and horizons and not having any problems, so it is your call. I already bump my cranks on rocks occasionally, so I don't think any shorter than 700x40ish will ever go on my bike, simply for that fact.
    Good luck, looking forward to seeing what you end up building!
  31. #531
    Reputation: joshhan's Avatar
    Mar 2011
    I was using Spyres on the Wolverine until one of the bolts seized and I rounded out the bolt in the caliper. They weren't terrible but they weren't that great either. If you want to keep your "brifters" try out the Yokozuna cable actuated hydro brakes. They are really nice and the kit comes with rotors and their really nice brake cable housing.
    I am being super lazy though and haven't replaced the front housing. I'm running on the rear and I can actually feel a huge difference in brake feel between the front and the rear. I'll get to it one day.
    Bikes, lots'o bikes
  32. #532
    Oct 2013
    Too funny!
    The new 105 (R7000) group is out and supposed to be very good. That would be a nice setup.
    I've loved both my Shimano SLX and Sram Guide hydraulics on my mountain bikes so I am very tempted by hydraulics as well. I love the modulation there and I almost never adjust the things.
  33. #533
    Oct 2013
    Quote Originally Posted by joshhan View Post
    So those are like the TRP Hy/Rd brakes? Cool, I hadn't heard of those. Were you turned off on TRP after the Spyres and that's why you got the Yokozuna brakes?
  34. #534
    Oct 2013
    Found a review that compares them favorably to the TRP Hy/Rd, but they are about $90 more expensive for a pair than the TRPs (at least for the quick search I did).
  35. #535
    Aug 2014
    I thought about those a lot - haven't seen a lot of feedback, good or bad, which makes me think that they are still relatively unknown. I think their timing was just unfortunate to bring those to launch - a lot of folks were already eyeing over full hydraulic systems when those launched, and Shimano/SRAM first gen road hydraulic systems had already come down in price.
    Alternatively, TRP has the Hylex full hydraulic system, that you can do di2 or gevenalle with, or of course bar end, single speed, or downtube shifters. I thought a lot about that too, because I like my end. I already had the TRPs and Tektro levers in my parts bin though, and couldn't justify spending that much more, so I went with what I had on hand. If I ever re-configure this bike, I will likely go with a Shimano 11sp hydraulic setup.
  36. #536
    Aug 2014
    I think the price difference is OK considering they come with decent rotors and a really nice cable kit - the cable kit is usually $60 for a front/back, which isn't really terrible on its own. But, for $125/wheel, that is in TRP Hylex territory, which is a full hydraulic brake. Throw in another $200 and you have whatever shifter setup you want through gevenalle, and that is a pretty reasonable price for a whole shift/brake solution. Just add a RD/FD and drivetrain, and you are in business.
  37. #537
    Mar 2011
    I have bought 2 sets (one for the commuter). I wait until the somafab.com has their 20% sales. So $200 - $40 for $160 shipped. I like them a lot, they brought back 1 finger braking and I don't need to upgrade my shifters.
    And as other posters have noted, they do come with the really nice metal, braided housing, rotors and mounting hardware.
    Bikes, lots'o bikes
  38. #538
    Aug 2014
    What is your opinion of the rotors? Also, what pads do those brakes require - is it a standard style pad, or would I need to order from SOMA/IRD/Yokozuna every time I needed pads?
  39. #539
    Mar 2011
    Rotors are fine, the pads are the same shape as the Shimano MTB pads so you have a variety of choices there.
    They are coming out with a 4 piston version soon from what I've read!
    Bikes, lots'o bikes
  40. #540
    First bought my 2.0 frame set back in 2016. Had it set up on 29" wheels as a drop bar single speed, flat bar single speed, with fenders, without fenders... Finally took the plunge and set up the bike as a 1x11 on 650b wheels. Apex 1 HydroR groupset, Stan's Crest Mk3 wheels, and WTB Horizon tires. Considering snagging a thru-axle front fork and rear sliders, but haven't really felt the need yet.
    On a side note, anybody else running Soma Junebug dirt drops? For some reason both my TRP Hylex and SRAM Apex levers have trouble achieving proper clamp load on these bars. The screw on the ring clamp bottoms out before the ring clamp has fully contacted the bars, meaning I can't tighten the screw down any further. I don't have this issue on another set Syntace road bars, so it's definitely the Junebug bar, not the brake levers. I can get around this issue by wrapping the bar a couple times with electrical tape, but this doesn't seem like something I should have to do.
  41. #541
    Aug 2014
    Warentee completed.. Don't like the gloss black like I did the orange. Left the steerer full length for now
  42. #542
    Yeah, the orange just had something special. I'm okay with the black. But the orange was better.
  43. #543
    Aug 2014
    Yeah I loved the orange. When I started the warentee process. Somone on the thread said the frame is e coated. I don't notice that, and I don't see that in the specs on the web site. Do I need to use some frame /rust protection? Or is it e coated?
  44. #544
    It's definitely e coated and it's very noticeable. No reason to avoid adding a second layer of corrosion resistance.
  45. #545
    Aug 2014
    Thank you
  46. #546
    Nov 2016
    Suggestions for 1x setup for Wolverine
    I just ordered a 56cm Wolverine and want to go with a 1x setup. My local shop suggested going with SRAM Rival. Are there alternative 1x setups people would suggest?
    Thanks,
    Chad
  47. #547
    Mar 2011
    Quote Originally Posted by ckinge View Post
    Thanks,
    Chad
    This is going to be an unpopular opinion but I hated 1x for gravel/trail riding on the Wolverine. I went 2x and love it. Lost too much on the highest and lowest gears when I ran a 38t chainring. I'm now on a compact crank (50/34) with a 11-36 10 speed cassette and love it.
    SRAM Rival levers
    10 speed X9 rear derailleur (type 2 clutched!)
    Rival front derailleur
    Otherwise, if you use SRAM levers, you can mix mountain and road 10 speed groups which is awesome.
    Bikes, lots'o bikes
  48. #548
    I run 50-34x11-42 on one of my bikes and love it. I'll ultimately run 42x11-50 on my bikepacker. But that's for simplicity, not for being ideal.
  49. #549
    Nov 2016
    Hi,
    Could you please share with me your entire 1x setup?
  50. #550
    It will be a 105 5800 crank with a wolf tooth 42t narrow wide chainring. XT-M8000-SGS rear derailleur, M8000 shifter, Sunrace CSMX8 11-50 conversion cassette.
    If I ever take it back to Drop bar, it will be with 105 R7000 hydro mechanical levers and a Wolftooth Tanpan adapter.
    The 2x set up is using dura ace hydromechanical levers with a Tanpan on an XT rear derailleur. Works flawless.
  51. #551
    May 2014
    Nothing really new here guys but still riding and loving my Wolvie! I checked back in after a long break and thought I would share some recent gravel grind pics. I was on a ride a few weeks ago and my Cazaderos, which had over half tread left, broke a belt in the front tire. It developed a buldge right in the center of the tread. I finished the ride but it progressed badly and barely made it back. The third pic shows my Wolvie currently sporting 43mm Gravel kings. I have yet to get out for a ride with these yet. They look sharp! Soma Wolverine Builds-file-ebb07a3f-30ef-46fc-8969-a799c57f20a2-692-00000065a54a7691.jpg
    Soma Wolverine Builds-file-eb8e46a9-689d-4b45-a514-ee8b132302c5-692-00000065a794e8a8.jpg
    Soma Wolverine Builds-file-09ee5f51-01ce-4fec-a618-68b079a280b2-620-0000005394cab680.jpg
  52. #552
    Aug 2014
    SRAM Rival levers
    Ha, I'm running that same gearing combo on one of my bikes. 5700 105 and 9 speed XT RD, and compact crank with 11-36 10 speed cassette. Makes for a great everything bike setup - always have a gear that works for whatever I am doing, even if I am carrying stupid amounts of stuff up a steep hill.
  53. #553
    Aug 2014
    Wolverine drive train setup
    Hey guys, posting because I had a few requests in PM about my drive train setup. Very happy with this drive train setup - reliable, easy to use, shifts quickly, and easy to setup. Hope this helps with your builds!
    Shimano M8000 XT RD, XT 11-42 cassette
    Ultegra crankset with Wolftooth 40t elliptical ring
    Microshift bar end shifter, 11 speed DynaSys compatible. BS-M11 is the part number - works perfectly with Shimano 11 speed MTB RD. Comes in pair with friction front too, if needed.
  54. #554
    Very slick, SpeedyStein!
  55. #555
    Aug 2014
    Quote Originally Posted by doismellbacon View Post
    Thank you!
  56. #556
    Reputation: SanJuanSam's Avatar
    Nov 2018
    Hey all. Iíve been stalking this thread for a while. I built up my Wolverine last fall. Totally loving the bike. Eventually Iíll post the build spec but for now hereís some photos.
  57. #557
    Aug 2014
    Quote Originally Posted by SanJuanSam View Post
    Right on, looks like you have built it up a few different ways so far. That's what I like about mine - it is super flexible to build up for whatever I want to do/ride. Which frame bag is the camo one? I really like the shape of that - looks like bottles actually fit in the cages with that one. I have the Blackburn Outpost bag and don't really like it much for this frame - I can't fit the bag and bottles at the same time.
  58. #558
    Nov 2018
    So the camo frame bag in the second photo is a Jandd. The other frame bag that is green/camo is from Oveja Negra. I like the bag from Oveja a bit more although requires the use of smaller bottles.
    In a short amount of time my wolverine has seen some different set ups. Mostly just wheel/tire changes. The move from a mountain triple to a white industries vbc double was huge. It allows running the tire as far forward as possible with clearance for the front derailleur. The 2.2 continentals had some interface with the front derailleur even slammed back in the dropouts. I heard about the frame failures right after installing those so I pulled em off and went to rock n roads which are great tires on this bike.
  59. #559
    Reputation: boostin's Avatar
    This is my Wolverine and my dog, they are both pretty fun to hang out with.
  60. #560
    Aug 2014
    Right on, Thanks for the info on the bags.
    Yeah, I ran 2.25 Nine Lines on mine for a little while, and didn't have FD problems because 1x, but I didn't really care for how the bike handled with that large of a tire. I switched to the WTB Resolutes and couldn't be happier - they are pretty similar in size/knob characteristics to the R&Rs.
    Thanks for sharing!
  61. #561
    Nov 2018
    Thanks for sharing!
    Recently I switched to a set of NOS WTB Mutano Raptors in 44. They are a great tire for this bike. Not too bad on pavement and perfect in the snowy conditions we have right now. This bike is making me become a tire/wheel set collector.
  62. #562
    Nov 2018
    Quote Originally Posted by boostin View Post
Name:	Moses Rez Raider Orange Harvester.jpg
    Iím digging the purple (I think) bar tape. What bars are those? Almost look like on-one midge.
  63. #563
    My friend who built it gave me purple housing so I bought a purple stem and purple tape for it. I think it looks pretty good! The bars are Salsa woodchipper 2's I am 95% positive.
  64. #564
    I have a wolverine frame that I am building up using parts bin components. I will need to make one purchase related to the wheels. I have an old DT Swiss X1600 rear wheel with with a 142x12 hub. I am debating whether to pay $40 for DT end caps to convert the hub to 135 QR or spending $65 for paragon sliders and hardware to convert the frame to 142x12. Thoughts? Any strong preferences on these two options?
    A related question. Paragon lists and sells the shimano AX-MT700 thru axle as being compatitble with their dropouts. I have an old SM-AX75 thru axle that I hope is compatible. Anybody know if it will work? I asked Paragon customer service and they refused to comment on its compatibility.
    I would really stick with DT Swiss for paragon drop outs. I know there are others that work. But DT is worth it.
    I strongly prefer the through axle rear end on my Wolverines. Having run both axle types.
  1. Any experience on a Soma Wolverine?
    By RPG in forum 29er Bikes
    Last Post: 05-31-2016, 01:54 PM
  2. Soma Wolverine is in the mail!
    By Agwan in forum Custom Builders & Other Manufacturers
    Last Post: 10-16-2014, 03:37 PM
  3. Replies: 1
    Last Post: 09-11-2014, 05:32 PM
  4. WTB Wolverine 2.2
    By ROCKHOPPER703 in forum Wheels and Tires
    Last Post: 08-10-2011, 04:55 AM
  5. What's up Wolverine?
    By boomn in forum 29er Bikes
    Last Post: 05-17-2011, 01:46 PM
Members who have read this thread: 127
