short bottle cage bolts?- Mtbr.com
Results 1 to 6 of 6
    try driving your car less
    Reputation: jh_on_the_cape's Avatar
    Hi, My Ted Wojcik and my Independent Fabrications steel bikes have bottle cage bosses that are sealed, so the bolts can bottom out in there. I am having a hard time finding short bolts, and if I use washers the bottles slide against the bolt heads.
    I checked multiple LBS and a hardware store, nothing. Anyone know someplace I can find some? Online is fine, or even just the bolt type. I think I need M5x6 or M5x8.
    Thanks.
    Only boring people get bored.
    Steady Creepin'
    Reputation: LuMach's Avatar
    Have a look at Purelycustom.com
    I got some nice bottle cage bolts from there that were a little shorter (about 2mm less) and lighter than the stock bolts that came with my bike.
    Reputation: dvo1's Avatar
    mcmaster.com
    Quote Originally Posted by dvo1
    mcmaster.com
    that's it. perfect thanks!
    m5x6 stainless bolts are Part Number: 91292A189
    $9.82 per Pack of 50
    m5x8
    DIN Specification Stainless Steel Type
    DIN 912-A2 18-8 Stainless Steel 91292A191 $8.83 per Pack of 100
    DIN 912-A4 316 Stainless Steel 92290A222 11.10 per Pack of 50
    I am going to check the length again before I actually order a pack of 50...
    I need at least 12. and they always come in handy.
    Unicycles are for clowns
    Feb 2005
    Better yet
    Save your money, I have an older Fat Chance that is the same as the Independent Fabrications, I used disc brake bolts - the bolts that you use to mount your rotor to your hub. Worked perfect.
    Apr 2005
    mcmaster.com
    That darn place has any and everything!
    Enjoy every ride!
