Team Blindspot
Shock size for KHS FR 1500
I just picked up this frame for my 13yo. It has a Vanilla R, 7.5 i2i. Is the shaft travel 2.0 inches? Or something else? I also need to get a different spring as it has a 700 x 2.3. Whick I pretty sure is going to way to much for a 150lb kid.
TIA
P.S. Anyother helpful info about this frame would be greatly appreciated.
Astigmatic Visionary
Chillin the Most
TIA
The shock is indeed a 7.5 i2i x 2.0 stroke. I would recommend a 500lb spring if you plan on running the 6" setting. The only other helpful info I can give you is don;t break it and expect any help from KHS. Otherwise enjoy.
Team Blindspot
Thanks for the info. I'm going to give him my romic from my spot to blow up first.
- You may not post replies
- You may not edit your posts
Forum Rules
