rear shock on extreme x2- Mtbr.com
    Apr 2005
    I have an '04 haro extreme x2, I want to try and get more travel out of the rear suspension does anyone have any suggestions?
    ouch
    Reputation: Spero's Avatar
    Apr 2005
    I dun think there's much room for more travel - I was just checking out my x1 the other day for the same reason.
    pwn3rator
    Reputation: scabrider's Avatar
    use a longer stroke shock and grind a space in the gussett on the swingarm behind the shock mount, pm westandablaze for more info...
    SOCAL UNION REPREZENT
    Quote Originally Posted by JBsoxB
    does it still qualify as a mountainbike?
    Quote Originally Posted by kidwoo
    I've beat beer cans on my limp pee pee.
    Aug 2005
    Caution;  Merge;  Workers Ahead!
    Quote Originally Posted by scabrider
    PLEASE do not do that!!
    you honestly will not nneed more than 6 inches if you can set the shock up right for waht you use it for. I recentlly went downhilling on an X1, and never bottomed it out of any drop, i had it loose all the way and rebound fast. dont worry about the travel, your fine with 6. your not doing 15 or 20 footers, other wise u would have a diff bike. but haros have strong frames, grinding it down would ruin one of the major pluses of the frame.just tighten your preload and make ur rebound like 3 clicks from the fastest. a friend has an x2, and he never bottoms his out just buy having it set right.
    wow and grinding a frame are that fvucking stupid?
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. 7.5" rear shock on a X2 frame
    By Weshwesh in forum Diamondback
    Last Post: 04-23-2005, 04:55 PM
  3. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  4. Replies: 45
    Last Post: 10-12-2004, 12:04 PM
