Question- Mtbr.com
Results 1 to 8 of 8
Thread: Question
    Nov 2008
    Question
    I weigh right around 180lbs. what spring weight should i run on my F5?
    Reputation: markskee's Avatar
    Click on "Rear shock spring rate calculator" and enter your numbers under input parameters.
    http://service.foxracingshox.com/consumers/index.htm
    Reputation: CHUMBAevo's Avatar
    I'd say most start at 300lbs., I think Markskee uses a 350 to run a little firmer - I would guess he weighs around 200lbs. as well.
    Simple | Proven | Reliable
    http://chumbaracing.blogspot.com/
    BrassBalled DropbarNinja
    Reputation: mrpercussive's Avatar
    i would think it would be like 350 as well... i'm 125lbs and use a 250... I think guys who weigh like 140 - 160 use the 300 just fine...
    Quote Originally Posted by mrpercussive
    What the ......you weigh 125lbs??? you need one of these mang.....or maybe forget a Ti spring run a plastic one (less weight).......jk mang shotski...!!!
    Quote Originally Posted by markskee
    dude... i've been trying to gain all the weight i lost from my time off... Back into training and doing weights... and guess what? No change... lols... Yes, i'd so eat that... XD
    btw, imma buy some used skis and make a SHOTSKI!
    Reputation: rollertoaster's Avatar
    I weigh 190 and just switched to a 400 on my F5 with a Vivid. Finally went an entire race weekend without feeling a bottom out. 300&350=Fail.... I was constantly breaking linkage hardware.
    Team _________
    Nov 2008
    thanks guys. im gonna try a 350
