1946:2006:2066
is it possible to retrofit frame reinforcement?
I have an early RM ETSX that has a small history of seat tube failure just below the upper
pivot mounts. The latest frames have redesigned pivot mounts that should prevent this
from happening. I am quite happy with my bike and tend to keep my bikes forever.
Is it possible to have a frame builder reinforce this area after the warranty has run out?
AND Is it possible to repair and reinforce it if the frame does break? All broken frames
seem to have a clean circumferential separation just below the pivot mount.
I am not a hard rider and there will be long periods when the bike sits. However there
will be equally long periods when you can't get me off the bike. It's one of these periods
outside warranty that concerns me.
Thanks for any input.
michael
Aluminum bikes are quite difficult to repair, because the frame will have to be re-aged/re-heat-treated after the repair is complete. If you can find the correct treating procedure, and a facility that will perform it, you may find success.
Without knowing what wall-thickness tubes were used, and where butt transitions end (etc, etc) it could be quite hard for a builder to know what to do to prevent a failure. Adding a gusset here might cause the whole thing to fail over there. Without seeing the frame, I couldn't even guess.
I'd probably leave it as it is until something happens. It could last forever. And if it does fail, you may want something else by then. Incessant *****ing and moaning to RM might help score you a reduced-cost replacement...
By MegaVolt in forum General Discussion
Last Post: 06-18-2009, 11:51 AM
By mojo in forum Vintage, Retro, Classic
Last Post: 06-20-2005, 02:26 PM
By BudhaGoodha in forum Bike and Frame discussion
Last Post: 08-30-2004, 10:53 PM
By ccm in forum Shocks and Suspension
Last Post: 06-15-2004, 08:37 AM
By derby in forum Bike and Frame discussion
Last Post: 03-11-2004, 05:20 PM
- You may not post replies
- You may not edit your posts
Forum Rules
