New Build- Mtbr.com
Results 1 to 2 of 2
Thread: New Build
    Jun 2005
    New Build
    Hey fellas,
    Just got my new Zion 737 EBB in and I am buying the parts for it. Soooo a couple of questions for the experienced guys out there
    1. What sixe tires can fitt 2.55 or 2.35???? Bigger the better I am going fully rigid (using the Zion fork that came free, score)
    2. I am not great with bottom bracket sizes and I know these things take 63mm but when I go to buy I see 63x57 and other different sizes, what sizes are you guys using.
    3. What are those cable guide inserts used on the disc brake cables (to keep the cable from moving to much around)? I am going to be running mechanical discs?
    Thanks for any help ya'll can give me and I will be sure to post pics when I get it all together
    Reputation: Badgerboy's Avatar
    1. can fit 2.35 rampages no problem
    2. currently using a un72 68mm shell width and 113 mm axle length
    3. used a piece of old road inner tube, open the guides up slightly, cut your tube and wrap around the cable outer or hose and then close them back up again
