Mountain Cycle Fury -Rear shock length?-- Mtbr.com
Results 1 to 5 of 5
    Hello,
    A friend of mine picked-up a used Mountain Cycle Fury frame without a rear shock. Does anyone here know the eye-to-eye lenth of the rear shock?
    Quote Originally Posted by signal
    Hello,
    7.5 inches. Did the frame come with the shock mount cleat? The stock Fury cleat will give the head angle around 70 degrees. If he gets the Sin slack angle cleat (undocumented modification) it will change the headangle to 69 degrees. I got mine setup for the slack angle and it's really sweet.
    Quote Originally Posted by racerzero
    Yeah, the shock size is 7.5" x 2" with 6x22 mounting hardware.
    The Sin shock mounting cleat makes the geometry slacker and also drops the rear travel some.
    Quote Originally Posted by TWISTED
    Friend of mine put a bigger shock which steepen the head angle. He then put the sin cleat which bought the head angle down. Not sure exactly what the specs are now but he really likes it.
    What does 6x22 mounting hardware mean?
    6x22 mounting hardware is the size of the hardware needed to mount a shock onto a Fury frame. 22mm wide with 6mm bolts.
