Maverick ML8 "Dahlia" build
Hello!
I just recently got my ML8 frame(2005) and a Fox talas 32 fork(9mm qr) and started building it up. I'm completely green when it comes to bikes so just a few quick questions. I'll post pics later ;P
1.
a) I have a pair of avid juicy 7 brakes and now need adaptors to fit them to the fork and frame. Which adaptors? I have no rotors yet. Fork has IS mounts.(Links from bikediscount would not be too shabby!)
b) What about some washer/bolt kit?
2. I have raceface cranks coming for it+BB(73mm). Should fit like a glove? Any idea on the spacer setup with the d-mount when fitting?
3. I'm going 3x9 and looking at the x9 medium cage. Will this work out alright or is the long cage a "safer" choice.
4. Is there anything extra considering the ML8 frame(wiring...etc..)? I already have the front derraileur.
This machine looks really awesome, can't wait to ride it : !
Ill update this post on the fly when I get answers and questions, thanks already before hand!
1. front and rear is IS, so you need adapters corresponding to brake caliper and brake disk.
2). cranks shopuld not be a problem. the alloy monolink is for 73mm BBs, so no spacers - unless you wanted/needed to adjust the chainline.
3). the medium cage might be fine up to say 34T at the rear - i believe i ran 3x9 like that for a while on the durance. if you run anything bigger for the cassette, then you should probably opt for the long cage. BUT - *seriously* consider going 2x10 if you can.
4). for the ml8, the rear brake line and the rear der cable do NOT cross behind the shock.
5). other comments - if your frame is long enough and the geo works out ok for you, i would suggest NOT using a seatpost with any set-back. for 'modern day biking' go with a beefier fork with more travel (150mm+) and more trail - fox generally has the shortest trail values when compared to other forks at any one particular travel value (e.g. 160mm), marzocchi generally the longest.
have fun ...
Hello!
Thanks for the answers.
What I currently have:
Frame: ML8
Fork: Fox Talas 32 IS mount
Wheelset: Random sexond hand
Tires: Maxxis
Seatpost: FSa 3d thingy
Headset: FSA
Incoming:
Raceface deus red 3x9 crankset
X0 shifters
About to order:
SRAM PowerChain II PC-971
Shimano Disc rotors 160mm
Sram Powerglide Cassette 11-32
Cube race Grips
X7 rear derailleur long cage
Hayes adaptor front IS 160mm
FSA adaptor rear IS 160mm
Left?
Stem+Handlebar
Avid caliper bolts
So what kind of bolts do I attach the break calipers with? The adaptors come with bolts but with what do I attach the calipers to the adaptor?
 Originally Posted by NikeMan
... but with what do I attach the calipers to the adaptor?
much the same ...
If you want to run the best front derailleur, Make Sure that you get the Shimano Flat Bar Specific Road front derailluer, FD-R453. You can use Shimano 10spd flat bar front derailleur if you cant find the R453.
105/Ultegra/Dura Ace have different cable pull and lever ratio which shift crappy in the Mavericks with the Dmount.
 Originally Posted by mikesee
Better suited to non-aggressive 125# gals named Russell.
I ride so slow, your Garmin will shut off.
Oh snap I got the 105 triple. But that will have to do for now. Still waiting for a package from bike discount and then I should be all set. This will be my first FS bike and I got to sit on it today and boy does it feel spungy compared to my old MTB. For reference, it is an wheeler 2800zx :P :P
By VFXterra in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 04-17-2015, 07:37 AM
By tsfdirect in forum 27.5
Last Post: 12-04-2014, 02:03 AM
By patineto in forum Maverick
Last Post: 02-21-2013, 05:41 AM
By Jasom in forum 29er Bikes
Last Post: 07-18-2012, 10:22 PM
Last Post: 02-16-2012, 11:08 AM
- You may not post replies
- You may not edit your posts
Forum Rules
