Litespeed Pinhoti Boost
Printable View
  • 09-04-2017
    farfromovin
    Had my local LBS, METALMTN cycling in Ventura CA, build a new hardtail for me.
    Frame- Large LS Pinhoti Boost
    Fork- Pike 120
    Headset- CC 40
    Stem- Ritchey WCS Trail
    Bars- Ritchey WCS Trail
    Grips- ODI Rogue
    Groupset- XX1 Eagle
    Rims- LB AM928
    Hubs- Onyx center lock
    Tires- Schwalbe HD 2.35 / Racing Ralph 2.25
    Brakes- Guide Ultimate 180/160
    Bottom Bracket- WheelsMFG screw together PF30
    Seatpost- Reverb with 1x remote
    Saddle- Selle Italia Flite Flow
    Pedals- Xpedo M-Force 8CR
    Bike is a rocket. I feel like I can descend my regular rocky trails just as fast as I could with my FS bike, obviously not quite as smoothly. However, where I ride you gotta earn it all. Lots of climbing here in SoCal, seems like I can't ride anywhere without climbing 1k'-5k'.
    I'm swapping the saddle for a carbon version and the bike has some older pedals on it while my Xpedo's get delivered. Still dialing in the Pike, I've only ridden it twice now and I'm coming from Fox suspension but so far no complaints.
    I wanted to build a bike that would hold up to my Clyde ass grinding up hills and always wanted a Litespeed frame. Something about bare titanium just screams timeless to me. Jack at Litespeed gave me a good deal on the frame so I pulled the trigger. Wanted to post a couple pics as I couldn't find much info on the web about this bike before I purchased it. I'll weigh it later this week but I'm guessing it's 24.X lbs. No featherweight but it's pretty tough!
  • 09-22-2017
    farfromovin
    Got a chance to weigh it today as my Xpedo pedals came in from backorder, 25.8lbs.
    No doubt the dropper, 120mm Pike, and wheel/hub choice arenít the lightest but they should last with me beating on it!
  • 03-02-2018
    StaticSag
    Beautiful bike and a great build! Canít believe no replies before me.
  • 04-07-2018
    CyNil_Rider
    Hey Farfromovin, sweet bike!! I hope it rides as nice as it looks!
    I just pulled the trigger on a new Pinhoti Boost too, so in "4 weeks" or so I'll be applying for membership to the club :)
    So cyked!
    Any thoughts on yours, 6 months in?
    Seemed like the setup was pretty dialed.
    Any mods since the original build?
    So that must be the dropper cable routed thru the headtube, yes?
    Any sign of water/dirt getting in through there?
    Can't wait to get off my way over-biked "big bike" (FSR Stumpjumper) and be gettin' back to my HT roots.
    Oh, and it's my platform for getting into bikepacking.
    I went with a Fox 34 Fit4 fork and the GX Eagle 1x12 groupset, Ibis 738 wheels clad in 2.5" Maxxis Aggressors tires, and stoppage provided by Guide R set up 180f/160r.
    I couldn't help myself and went and added a dropper- Fox Transfer with remote, but know I will be glad I did.
    Still room for future upgrades (fancy rims/hubs, brakes possibly) but pretty close to my ideal-bike-I've-never-ridden!
    Cheers!
  • 04-20-2018
    farfromovin
    So cyked!
    Cheers!
    Yeah, Iíve changed it a bit. By far the biggest change was I swapped out the Onyx hubs for DT240s hubs. Someone just bought my cranks so I have XX1 DUB cranks on now. Running Maxxis Ardent Race 2.35/Ikon 2.2 tires, ESI foam grips, S-Works Phenom saddle. Just, as in today, put on Speedplay Syzr SS pedals. Thatíll take take some getting used to but Iím super stoked about those!
    For the dropper, yeah it runs out of the head tube. Not intended for a cable housing, itís for Di2 routing but it works with the hydraulic reverb!
    The bike was at 25 lbs even and I think I dropped about 3/4 lb. thinking about a lighter SID fork too.
    A lot of folks here in SoCal run the ďbig bikesĒ like you mentioned. I donít know why besides comfort. My HT is just as fast downhill as my Fuel EX was and itís faster up. My overall impression of this frame now is itís a good compromise. Itís not a lightweight carbon racer and itís not a long low slack 29íer either.
    Ideally with a different fork, and if I could change to a KEV CI dropper, Iíd like to sit around 23 lbs even. Thatíd be pretty good for a metal bike with a dropper built to take a beating.
  • 12-10-2018
    tri-tele
    Just bumping this up to see how people have been liking the Pinhoti... considering one for an SS build.
  • 12-10-2018
    CyNil_Rider
    I am pretty happy with the Pinhoti overall.
    (As a frame of reference, I was very happy with the fit and geo of my 2010 Rockhopper).
    Overall for a hardtail, I would say it is reasonably lively, but not particularly flickable.
    The rear through axle is a big plus in tracking and makes for good stability in hard cornering.
    Though similar in HA, it has a longer chainstays and wheelbase than the rockhopper, and feels it. It takes a fairly heavy input and I find I must 'drive' through the turns. I still tend to over-steer with too much weight on the bars and have the front just dig in, where the 'hopper would just whip around/through... I'm learning to adjust my body position further back to compensate.
    The Pinhoti, with 2.5" tires on my 27.5 alloy rims makes for a solid-feeling, if not light bike.
    I can get small air, at speed, and it feels composed and predictable through the landing.
    I will likely go to 2.4" tires as I find the 2.5" a bit bouncy<->mushy for me (I'm ~175lbs, kitted up) and the addn'l traction isn't necessary and doesn't justify the added weight.
    Unrelated to Pinhotis in particular, but the dropper is a complete game-changer. Duh.
    It's no carbon whip, and there are plenty of steel/alloy options for waaay less $$$, so it really depends on what you value. I'm assuming I can hand mine down to the grandkids!
    Oh yeah, I'm starting to dig the plain-jane finish, and I really love that is it is not secretly rusting away somewhere!
  • 10-19-2019
    Cayenne_Pepa
    Been lusting for Litespeed for a long time. Very robust build OP. Here is my 22-pound Titanium Singlespeed:
  • 05-27-2020
    bigk9big
    Iím building a Pinhoti now. Pulled trigger on very low Ti pricing right now. Always wanted a Litespeed. Keep this thread alive. Iíll post the bike when itís built. I cracked my carbon cross tube on an endo recovery... and Iím 60 and wasnít shredding. Thought, no more carbon, donít care about weight as much, and love Ti.
  • 08-28-2020
    daguillard
    Hey CyNil Rider. If this thread is still alive, can you say how it's worked out for you bikepacking? I'm thinking of using it for a build, same purpose. It's darned close to the Fargo, and a lot less $$.
    David
  • 08-31-2020
    CyNil_Rider
    David
    I'm busted! TBH, I barely ride it.
    It is a super ride- lively, responsive, light! And yet...
    I haven't forced myself to get used to the 27.5/2.5s. Wagon wheels, I say.
    Plus I built up my 2010 Rockhopper 26er while waiting for the Pinhoti build up, and seem to end up on the 'hopper almost exclusively. Fit matters!
    Should probably sell the LS...
    But I am sure it would work out as an excellent platform for bikepacking.
    Note, mine came set up for 2 bottle cages and external cable routing.
    Not sure if options have changed.
  • 08-31-2020
    CyNil_Rider
    niioce!
  • 09-23-2020
    rainking
    Dropper post routing
    Groupset- XX1 Eagle
    Hi!
    I just picked up a Pinhoti Boost. New to me is the dropper post cable routing through the bottom bracket (BB) shell. It looks like you have the cable passing into the head tube and down through the down tube into the BB shell and up the seat post. Is this correct?
    The reason for asking is to make certain that there is clearance for the cable in the frame. And, that the cable housing bends are not too severe.
  • 09-26-2020
    rainking
    I am pretty happy with the Pinhoti overall....
    Yo! Did you zip tie both the rear brake line and the dropper cable together? I have only one set of cable guides on the frame.
    Stuggling to make the dropper post work .. elegantly.
    Best I can tell, this image shows cable guides that have been attached to the frame for the dropper.
    Attachment 1366411
    Running the dropper cable on to of the brake hose may be fine... ?!
