Just Purchased a Zion 660 EBB . . . .
Hello all,
I just picked up a Zion 660 EBB frame for a steal of a deal ($115), at that price I could not let the chance to build up a SS escape me. Problem is I have never built a bike before, so this will be my learning curve, as such I have a few noob questions (Please forgive my lack of knowledge):
1) What size headset do I need? (assuming the standard 1 1/8)
2) In terms of cranks for a Single speed, what are some good options and what sizing is best/applicable for the Zion frame? What size Bottom Bracket does the Zion frame require?
3) Also what gearing is recommended for someone new to the Single Speed world? I am a farily decent climber, so I would like something that will not be pedalled out in the flat sections of a course, but at the same time something that will allow me to climb and not walk the hills.
So far my build is going to be as follows:
Zion 660 EBB Frame
Fork - ????
Mavic Crossride Wheelset
Cane Creek S3 Headset 1 1/8 (if applicable)
Juicy 5's Hyrdraulic Discs
Crankset - ????
Gear Ratio - ????
Any suggestions on a decently cheap fork (around $250 -$300) for the build would be appreciated, I am thinking max of a 100 mm travel - Maybe a RS Tora?
I have some time to build this as I currently have a SantaCruz Blur LT which will continue to be my primary bike, but the urge to build a SS needed to be addressed.
Again, I apologize for my lack of knowledge and thanks in advance for all your help.
Cheers All
carpe diem
Some answers...
1) What size headset do I need? (assuming the standard 1 1/8) - 1 1/8" is correct
Depends on what you want to spend. You can find a cheap (or pricey) triple and only use the middle ring or pick up some crankarms and bolt on a 32 or 34T ring. On a budget, I would go with an older square taper crankset or arms (like Shimano or Raceface) and matching BB. You will need a 68 x probably 113 BB english thread. I have ISIS cranks / BB on my SS and have durability issues with the BB, so I would not recommend ISIS.
Gearing is personal and somewhat depends on terrain that you ride. More hills might dictate more teeth on the cog. Rule of thumb is 2:1 or slightly bigger so with a 34T ring you might go with a 17 or 19T. My suggestion is to ride your current bike in the middle ring and the rear cog in the 16 - 19T range without shifting on your favorite trail and see how you do.
Zion 660 EBB Frame
Fork - ????
Crankset - ????
Gear Ratio - ????
Plenty of options from 80mm or 100mm or rigid.
If your trails are fairly smooth, you might consider a rigid fork for efficiency and simplicity. Otherwise here is another option if you are looking at 100mm:
http://www.speedgoat.com/product.asp?part=106942
Free shipping on orders more than $100 if you were in the states.
For reference, I currently ride ride a 29er SS and I'll be building up a used 853EBB for a friend. Good luck on your build.
Cheers.
Check the General and/or Shock boards before getting a Tora. RS is having issues w/ a seal leaking.
I've got one coming to replace my older Marz Bomber, so if you want to buy a used 100mm fork, let me know. I've got to make sure the Tora works, first, though.
fp
- You may not post replies
- You may not edit your posts
Forum Rules
