Independent Fabrication Question- Mtbr.com
    Reputation: schneidw's Avatar
    Mar 2005
    Does anybody know where/how to decipher the serial number of Independent Fabrications to learn about the year of construction.. I just purchased an used IF frame that has a SN# of 468D222.. Any ideas?
    jct
    jct is offline
    Reputation: jct's Avatar
    468 - 468th frame of the year
    D - Steel Deluxe
    2 - made in 2003
    22 - 22" frame
    that's taken straight off the IF owners site. is your frame a 22"?
    Mar 2005
    As always, insightful comments galore from MTBR. I just measured the frame C-C and it was 22-in as you predicted... Thank you for the insights.. so I assume it must be a 2002 model.. The frame does have the bent chainstays and seatstays for better tire clearance. Seems like an odd size so I assume the frame was built to custom specs. I am stil on the fence.. The Inglehart fork seems very appealing especially given his past expereinces at Fat City Cylces... I checked his website and he seems only to sell frames and forks as sets... I will drop him a line... I am leaning towards the Salsa or IRD simply to keep costs down.. Still need to check on the rake and length specs...Thanks again
    853+29+1x24=Fun
    Reputation: kev0153's Avatar
    Sep 2004
    There will be a C after the size if it is made from custom geometry. This might have the standard geometry just a really big size.
    71.5 HT angle 72.0 seat tube angle
