evo with zoke 66- Mtbr.com
Results 1 to 6 of 6
    locked - time out
    Reputation: TIMBERRR's Avatar
    Feb 2006
    evo with zoke 66
    Anyone put an '07 adjustable 66 (140-180mm) on an evo yet?
    Made in China
    I know someone tried a 05 66 and the front is way too high and it also raised the BB too high. It jacked up the handling too much.
    He also put a 06 66 on which has shorter AC height which was enough to bring the front down to almost normal height and maintain the handling. I loved that combo.
    05 66 AC 595mm
    06 66 AC 555mm
    40mm is a big difference, If 07 has almost the same AC height around 555mm so it should be pretty good on the EVO. It would make the EVO a kick A$$ FR bike.
    "Didn't your doctor tell you to stop smoking and drinking?" George Burns "Yes but they all died"
    Time is not a road.
    Reputation: chad1433's Avatar
    I don't think the '07 66s are out yet to the mainstream public.
    The Marzocchi website lists the A to C at 565mm, so I'm guessing that's at 180mm of travel. That's not too bad, really, and with 40mm of travel adjust, this fork could fit a lot of different bikes...moment
    not so super...
    Reputation: SSINGA's Avatar
    FWIW...the 06 66SL has the same 40mm adjustability but requires the use of a low pressure pump.
    Nothing to see here.
    Reputation: CHUMBAevo's Avatar
    Our intern Oliver put a 66 on his EVO and uses it as a trail and DH bike. Here's a pic of one of our EVOs with a z1 light.
    Simple | Proven | Reliable
    http://chumbaracing.blogspot.com/
    Time is not a road.
    (I should have read it better!)
