EVO rockers- Mtbr.com
Results 1 to 6 of 6
Thread: EVO rockers
    yarrrp
    EVO rockers
    SO...there are two different rockers now for the EVO. The ones for the freeride are the OG rockers and you have some newish nifty ones for the other evo? Do they lower the BB and slack it out? Explain please.
    They're the same geo except the Taiwan ones have double bearings in the back also.
    Oct 2007
    So the dual bearing rockers will fit any Evo? Because one of the rear bearings is loose in the rocker and its rubbing the seat stays. Poor press fit of bearing I would guess.
    yarrrp
    Tighten your bolts
    Oct 2007
    Come on!!
    The bolt isn't loose. The bearing is loose in the rocker. It looks like when is was pressed in it was a little crooked and removed some of the material in the press fit. The rocker can be moved in and out about a 1/16th of an inch. You can disassemble rocker and pull the bearing out with your fingers.
    Is this thing on?
    Reputation: Bradfly85's Avatar
    The best thing to do is email Brian, Alan, or any of the guys at Chumba and I feel more than confident they will help to resolve any issue you may be having.
    Or even just call them!
    [[/B][/FONT]
