E-type & bottom bracket/crank spacing on new EVO
Just got my new EVO.
Running the FSA Gravity setup, 2 ring for a crank. Also a Shimano E-Type derailer. Upon initial installion using the instructions provided for the crank/BB It called for zero spacers on both sides. Got it installed and the inner chain ring on the drive side was rubbing on the derailer.
I Pulled the Cup/Bottom bracket back off on the drive side, added a one spacer between the cup and derailer hanger, now I have no clearance issues. Just wanted to verify this is the correct amount of spacers on the drive side.
Allen
a 1.5mm spacer on the driveside should be fine!
A.
Thanks for the info...
BTW the bike is sik, I will post pics later
- You may not post replies
- You may not edit your posts
Forum Rules
