Builders for S&S Couplers retrofit on Ti- Mtbr.com
Results 1 to 6 of 6
    Apr 2005
    anyone have experience in havoing their frame "retrofitted" with s & s couplers?
    i have a ti 29er frame and i am playing with the idea of having the couplers added to my frame.
    any specific builders i should look at?
    price?
    TIA
    Schipperkes are cool.
    Reputation: banks's Avatar
    You should first call S&S to make sure the tubing is the correct size.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Sep 2004
    try DeSalvo
    He's done a bunch of S and S in ti and steel.
    I like to start out slow and then back it off a notch.
    3.14159265358979323846
    Reputation: velocipus's Avatar
    Apr 2005
    DeSalvo's good. There is also I.F. Dean may be the least expensive. They charge $175 labor (I believe) plus the cost of the couplers.
    try driving your car less
    Reputation: jh_on_the_cape's Avatar
    I looked at this, didnt do it, but would have used Bilenky in Philadelphia as I think they have the most experience.
    Every place charges more or less the same. If you can find a place locally, that would save the time and expensive and potential damage of shipping. They will also help you in person to figure out how to pack it all up.
    Most places will not do retrofits, just new builds with the couplers. Some builders suggest not retrofitting, but just selling the old frame and getting a new one because retrofitting can result in a frame out of alignment. That said, I have heard of tons of people getting a frame retrofit without any problems.
    Only boring people get bored.
    Mar 2005
    Builders on the west coast [steel frame]?
    Are there builders on the west coast that will retrofit?
    I travel for work a lot (> 100k miles/year), and I'm at the point that I'd like to bring my bike occasionally. I measured my frame to see if I could build a case that I could take on UA as checked luggage, and it is about four inches too long (L+W+H=62").
    Rather than get a custom frame built with the couplers, and worry about damage or theft while out of town, I'd rather just get an inexpensive frame (On-One singlespeed?) retrofitted.
