WTB Volt Saddle Noises- Mtbr.com
Results 1 to 9 of 9
    Mar 2016
    Has anyone had any issues with their WTB saddles (specifically the Volt) making noise from the underside of the saddle. The noise emanates from from plastic molding where it makes a cracking/popping sound. I can push on the saddle and it makes the noise, although it is not as pronounced as when I am seated and riding. This is the second WTB Volt saddle I have had this issue with. The previous versions of the Volt saddle were fine. I have tightened the small bolts under the seat which run around the perimeter of the saddle which seemed to help a little. I was just wondering if anyone has had issues with theirs as well.
    Jul 2013
    Try to oil some spots like the rails that touch the plastic.
    Shartacular Spectacular
    Reputation: Shartist's Avatar
    Aug 2018
    Iíve experienced this phenomena as well, then I washed out real bad in a turn two weeks ago and turned the rails of that volt race into something more closely resembling a modern art piece. Iíve since purchased another and it doesnít seem as noisy... yet...
    18í SC Bronson Carbon
    Grip2, Reserve 27's, i9's, Float X2
    18' SC V10.6
    Grip2, We Are One: The Outlier, i9's, Avy Woodie
    Mar 2016
    I love the Volt saddle...great fit and light. I'm going to lube where the rails run up and into the plastic molding under the saddle (thanks Carpetbomber!). I think that is exactly where the noise is coming from. Thanks guys, I'll circle back and let you know if it worked. Rubber side down.
    I have an Ergon saddle that creaks too. A little Tri Flo where the tails enter the saddle quiets the creak.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Yeah. I've had good results using a dry film lube sprayed where the rails enter the saddle base. Sailkote is what I typically use.
    Do the math.
    Mar 2016
    I used Militec-1 dry impregnated lubrication at the rail/saddle base junction and it eliminated the cracking/creaking. Thanks for the help.
    Aug 2015
    My Volt CrMo creaks to high heaven. The rails going into the nose move quite a bit as well. My Ti Volt has neither of these. Wonder if its limited to the CrMo?
    Mar 2016
    Both of my titanium Volts were creaking. The dry lube solved it.
  1. Norco Fluid WTB Volt Saddle
    By mLeier in forum Norco
    Last Post: 10-19-2018, 05:55 PM
  2. new saddle: WTB Rocket, Volt VS Fizik Tundra, Gobi?
    By FishMan473 in forum Components
    Last Post: 02-08-2016, 01:40 AM
  3. WTB Volt or Rocket v
    By GregQ in forum Components
    Last Post: 07-29-2015, 11:18 AM
  4. WTB Volt Team Saddle $59.00
    By stickman83 in forum Where are the Best Deals?
    Last Post: 11-20-2013, 09:47 PM
  5. WTB Volt saddle?
    By Noclutch in forum General Discussion
    Last Post: 06-27-2012, 02:35 PM
