Works angleset- Mtbr.com
Results 1 to 12 of 12
Thread: Works angleset
    Works angleset
    Looking for some assistance on a work components angle set.
    I installed it for the instructions. when I put my fork back in I noticed there is a bigger gap towards the back versus the front. I used the crown race that came with the works component headset. It actually slipped onto the fork pretty easily. I do get some creaking from the front end I'm thinking it's probably because of this gap. This is a negative 2 degree angle set. Zero stack upper and External cup lower on a straight 49 headtube.
    Sent from my Pixel 3a using Tapatalk
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Well if it slipped on, that's definitely a red flag. I thought my headset was bad, but it turned out to be my fork crown-steerer interface that was creaking. I only have a 1 degree Works. It looks totally flush to me.
    Mar 2014
    The crown races that come with the works headsets have a "split". They are designed to be installed without tools. I'm not sure that's a red flag.
    Sent from my moto g(7) power using Tapatalk
    Mar 2014
    Quote Originally Posted by mobilenemo View Post
    Are you sure the cups are aligned properly? Is there any binding in the headset? Are you sure that you chose the right cups for your frame (the cups are specific to a narrow range of headtube lengths). If all that checks out, and the only issue is the visual discrepancy in gaps front to back, I wouldn't worry about it.
    Mar 2014
    I appreciate the responses.
    I ordered the correct headset. The bike has a straight 49 headtube and measured 118mm tall. The size i ordered fits between 116 to 123mm. Zero stack upper and external cup Lower for a tapered steerer. Fork is tapered.
    The upper bearing has a much tighter fit in the cup vs the lower bearing. The upper bearing is tight enough that I needed to tap the bearing out from the bottom for removal. The bottom bearing can be pulled out easily by hand.
    There's no binding when rotating the handle bars, it's all smooth.
    Mar 2014
    How bad is the creaking? Have you applied grease to everything? I'd grease the cups before reinstalling the bearings, grease the csu before reinstalling the crown race, and grease the crown race before reinstalling the fork into the headset.
    When I installed mine the bearings sat VERY tight in the cups. They were so tight that I thought to myself that they were going to be extremely hard to get out when itís time to replace them.
    Things definitely donít look right and creaking is a sign of an issue. Remove and reinstall?
    I reached out and sent photos to works components. They said the install looks ok and are sending a replacement lower cup.
    Attached are photos of the initial install. I greased up all the parts during installation
    May 2020
    What bike is that? I dont recognize the logo.
    Ive been looking for straight 49 headtube frames and its impossible to search for frames based on headtube dimension. Everything I find tends to be tapered.
    Reputation: 006_007's Avatar
    Quote Originally Posted by Whiterabbitt View Post
    Its an older Knolly (all the newer ones have a 44mm upper 56mm lower tapered headtube)
    It's a knolly chilcotin.
  1. Replies: 20
    Last Post: 05-19-2013, 11:36 AM
  2. Replies: 1
    Last Post: 01-24-2013, 07:32 PM
  3. Paid Spam: Works Components 1* angleset for 1 1/8 headtubes
    By stumblemumble in forum California - Norcal
    Last Post: 12-31-2012, 04:00 PM
  4. 1.5 Steerer and Angleset/Works
    By arkon11 in forum Downhill - Freeride
    Last Post: 12-11-2012, 08:02 AM
  5. Angleset/Works HS and BB height, how low is too low?
    By Professional in forum General Discussion
    Last Post: 08-08-2012, 07:17 PM
Members who have read this thread: 67
