Use new cable housing with new Dropper Post- Mtbr.com
Results 1 to 7 of 7
    May 2019
    Hi all,
    I'm about to install a OneUp V2 dropper post to replace my (crappy and tired) RaceFace Aefect dropper. New dropper/remote came with a new inner cable and a new outer cable housing. I know I should use the new inner cable, but what about the cable housing? Is it a wear item?
    I'm leaning toward not replacing it, that way I don't have to cut my new one to length and reroute it through my frame ('19 Santa Cruz Chameleon Aluminum).
    Any input would be appreciated!!
    May 2019
    Picture of the tricky cable routing for the AL Chamelon, for reference.
    Attached Thumbnails Attached Thumbnails Use new cable housing with new Dropper Post-stw-2019-03-04-img_5241.jpg
    Practice Gratitude
    Reputation: Plusti's Avatar
    I'll try and answer... I'd say you have nothing to lose by trying to first re-use the old housing. I've done so a few times with derailleur housings with new cables and had success. If you don't get the performance you're looking for than go back and install the new housing instead?
    Beautiful bicycle and looks well maintained. With your maintenance and being internal routing I bet the outer cable housing isn't worn out just yet.
    Keep us updated and best regards,
    Jason
    “It never gets easier, you just get faster.” ~ Greg LeMond
    2012 Specialized Carve
    Jan 2009
    housing wears out more than the inner wire. I'd rather replace a segment of housing and reuse the wire if I had to choose one or the other.
    May 2019
    Quote Originally Posted by Plusti View Post
    Unfortunately that wasn't my bike! Just a picture I took off the internet as to describe the awkward bend the dropper post housing does on this frame! I appreciate the compliments though.
    I ended up keeping the existing housing. I still have the brand new cable housing it came with if I need to use it in the future. I still have no idea how I would route it without one of those fancy magnet tools! Imgur album: https://imgur.com/a/YrtfpwT
    Reputation: slomtbr's Avatar
    Oct 2010
    You can use this to join the housings and use the existing housing to pull the new one through the frame.
    https://www.sram.com/en/service/models/tl-rvbt-bc-a1
    Almost = Didn't
    May 2019
    Quote Originally Posted by slomtbr View Post
    Oh wow. That's a great idea, I'll have to get one of those for the future. Thanks!!
  1. Mach 4 - Dropper post cable housing routing
    By edbraunbeck in forum Pivot Cycles
    Last Post: 10-12-2017, 07:32 AM
  2. Replies: 15
    Last Post: 10-20-2014, 12:11 AM
  3. Is the shifter cable/housing the same as my brake cable/housing
    By dstorjoh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2012, 09:18 AM
  4. Rear Derailler Issues: dirty housing, full housing, new housing?
    By TwoHeadsBrewing in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2011, 10:49 AM
  5. Replies: 2
    Last Post: 02-10-2007, 06:45 PM
Members who have read this thread: 32
