are there really no 50mm rise 35mm clamp handlebars?- Mtbr.com
Results 1 to 19 of 19
    Feb 2018
    I'm currently on Renthal fatboy lites with a 40mm rise which i like, but could use a little bit more rise. I've been searching for weeks and cant find any 35mm handlebars with a 50mm rise. Do you guys know of any?
    I finally resolved to pulling the trigger on a 31.6 stem and either the spank 800 race or deity highsides until i realized how much more they weighed. Might be my only option though. Crazy how a smaller diameter setup nets more weight
    2019 Trek Farley 9.6
    2018 Trek Stache7
    2017 Hightower S+
    2016 Superfly 9.6
    Short-Change-Hero
    Reputation: gregnash's Avatar
    35mm Clamp standard is still fairly new to the consumer market, really only been around for a few years and companies are just not starting to build out their product lines with it (e.g. Deity Components just entered the race this year).
    50mm rise is not really a "standard" rise as most companies will focus on the "norms";
    Flat, 10-15mm, 20mm, 30mm and 40mm. Anything more than that the MTB communities sees more as a "bmx" type riser.
    Trying to be helpful
    Reputation: Guy.Ford's Avatar
    I think there is maybe one, its overseas which means PITA to get. Sadly went through this same thing months back, SOL, either have to stick with 31.8 or run more spacers under your stem for 35mm bars.
    FWIW, I run the Spank Spike Vibrocore bars, never weighed them (site says 360gr) but they are nice. I believe Enve makes really nice relatively light carbon 50mm bar (265grams) if weight is really a concern. Personally not much difference between the Rental Fatbar 40mm (315gr) vs the Spank Spike Race 50mm (330gr).
    #THELEGENDMTB
    2016 RSD Mayor
    2018 Diamondback Release 5CA
    Feb 2018
    Unfortunately i'm maxed out on spacers on both of my bikes : ( I'll check out the Enves, i didnt see them in my searches, or maybe ruled them out based on price. I've only tried one set of carbon 35mm and found them a little harsh (bonty line pro). The fatbar lites i run are only 270g. I dont care too much about weight, but when spending money to upgrade parts, i *hope* to decrease weight.
    Thanks for responses
    2018 Trek Stache7
    2017 Hightower S+
    2016 Superfly 9.6
    Apr 2016
    Have you tried finding a stem with a +\- 5 degree rise? I believe that will get you another 5-10mm, depending on the length.
    Sent from my iPhone using Tapatalk Pro
    Reputation: Heist30's Avatar
    Apr 2018
    are there really no 50mm rise 35mm clamp handlebars?-ce41ddb2-1b12-485d-ab62-f2f5b088325a.jpg
    I could not find any in 35mm either either so I resolved to a Diety Highside
    mbtr member
    Reputation: scottzg's Avatar
    I vote for upgrading to a 31.8 stem.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Na
    Feb 2019
    I agree, just got some spank spoon 60mm rise bars at 31.8 and they're pretty awesome.
    Feb 2018
    Quote Originally Posted by jrs77 View Post
    I currently run a 50mm stem with 6* rise. Not finding anything much better than that in either 35 or 31.6
    Quote Originally Posted by Heist30 View Post
    Is that the 50 or 80mm rise?
    Quote Originally Posted by krankie View Post
    Nice
    2018 Trek Stache7
    2017 Hightower S+
    2016 Superfly 9.6
    Apr 2018
    Quote Originally Posted by Gendy View Post
    80mm... Definitely gives a different feel and itís all good! Donít put as much pressure on the hands allowing more relaxed control and movement while keeping weight balanced.
    Reputation: Frantic29's Avatar
    Apr 2017
    Trek has the Bontrager Kovee Pro stem that is a 13 degree rise in a 35mm. Iím debating between that or going to 31.8.
    Feb 2018
    Quote Originally Posted by Frantic29 View Post
    wow, good find! Ill do some research on it. Maybe i'll just go that route and another set of renthals for now (which cant seem to be beat for price/functionality/weight)
    2018 Trek Stache7
    2017 Hightower S+
    2016 Superfly 9.6
    Aug 2017
    Anything new in this department?? I'm on a 35mm diameter stem but also need another 50+mm of rise on an 800mm carbon bar. I'm fine with going back to 31.8 stem (50mm). Angled stems aren't ideal as they drop the reach further, which is one of the reasons I'm trying to get a higher rise bar.
    Enve seems to be the only carbon option. I have some Diety Highsides on my DJ which are nice but 760mm (tho 80mm isn't enough there and I had to use a gooseneck stem).
    Curious to see if anyone else has this dialed in. My ideal is a 50mm stem with 60mm of rise carbon bars at 800mm width.
    Maybe a new 35 diameter stem thats 60mm but with 17d a rise would cut it? Right now I have 35mm rise bars and a 35diameter 50mm stem with zero rise. 25 to 30mm of spacers under the stem.
    Apr 2018
    This dude illustrates the DMR Defy stem gives 15-20 mm over your standard stem due to the low profile clamp!
    https://m.youtube.com/watch?v=9oxkX-PW0RA
    Aug 2017
    While it will allow your bars to get higher, it basically just allows you to get more spacers under the stem without it overflowing over the top. That's all good, but it also reduces your reach etc which is the advantage of higher rise bars rather than spacers and a low profile clamp like this.
    Apr 2018
    Quote Originally Posted by svinyard
    ...Maybe a new 35 diameter stem thats 60mm but with 17d a rise would cut it? ...
    Ya lost me...So this in a 50mm achieves a dissimilar result than the riser stem scenario you asked about by reducing reach?
    are there really no 50mm rise 35mm clamp handlebars?-3f624147-b3a8-4bfd-9219-2c5e7328c07b.jpg
    RAKC
    Reputation: tigris99's Avatar
    Geometry 101.
    Unless you roll your bars forward so they are perpendicular to the ground, ANY RISE will reduce reach. At the bars or at the stem, reach is lost no matter what unless you roll the bars forward to increase the reach. Which guess what, same thing can be achieved by a longer stem as well.
    Sent from my SM-N975U using Tapatalk
    Reputation: jeremy3220's Avatar
    Jul 2017
    The steering axis (the real frame reach) is fixed (unless you have a frame with adjustable geometry). Wherever your hand position ends up relative to the steering axis, it doesn't matter how you accomplish it.
    Aug 2017
    Its been a while. I think I was a bit confused. Yeah so now I'm on a 50mm zero rise stem with 20mm of spacers. This new stem in a 60mm length (to account for the extra rise/lost actual reach) and extra spacers would get me closer to my desired grip position.
  1. Replies: 0
    Last Post: 09-13-2016, 07:26 PM
  2. low rise or high rise handlebars?
    By aLLboutLx in forum Beginner's Corner
    Last Post: 08-15-2016, 09:22 PM
  3. Low Rise vs High Rise Handlebars...Help!
    By cham in forum General Discussion
    Last Post: 08-15-2016, 05:32 PM
  4. Replies: 10
    Last Post: 05-11-2013, 12:37 PM
  5. Rise Handlebars V.S. Flat Handlebars
    By howieizme in forum 29er Bikes
    Last Post: 06-01-2008, 09:52 AM
Members who have read this thread: 80
