Stem size/angle advice please.- Mtbr.com
Results 1 to 13 of 13
    Oct 2019
    Hi everyone, I have recently, 11 weeks ago, had both knees replaced, Previously I was quite bow legged leaving but now am straight legged & have gained one inch (25 m.m.) in height. Consequently I have raised the saddle height by one inch but that has placed a lot of weight on my wrists & I'm looking for advice regarding the stem size & height I should be looking for to return me to the previous riding position. The bike is a Trek Marlin 5 29er & the relevant geometry details are
    Fork: SR Suntour XCE 28, coil spring, preload, G2 Geometry w/51 mm offset on 29ers, 100 mm travel (13.5: 80 mm travel)
    Stem: Bontrager alloy, 31.8 mm, 90 m.m. 7-degree, Blendr compatible,
    Head set1-1/8˝ threadless, semi-integrated, semi-cartridge bearings.
    I'd be most grateful for an answer or details of how to work out what I need.
    Many Thanks, Steve.
    Nov 2016
    If you raised your saddle, 1) look at the saddle angle as angling the nose up ever so slightly will tilt your pelvis back to a neutral position if it isn't there already, and 2) you may need bars with a bit more rise to compensate for the increased saddle height, to bring the bar/saddle height ratio back to where it was.
    Is your stem angled up or down? Do your bars have any rise?
    Nov 2017
    Since your seat tube is angled you are now sitting about 6-8 mm further back as well as about 25 mm higher than before. If you have the room I'd first adjust your seat position forward to compensate for the rearward shift.
    After that you'll want to get an additional inch of rise in your cockpit through a combination of stem and bar changes. If you want to get that much rise through stem alone you'd need to increase both stem length and rise angle by an amount that depends on your head tube angle. At a guess I'd say you'd want something around 100 mm length with 25 degree rise angle, but you may need to experiment a bit.
    Oct 2019
    Quote Originally Posted by matt.s67 View Post
    Thanks for your response Matt & to answer your query the stem is 6+, it is angled upwards. I'm going to move the saddle forward a little & angle it up as you suggest & see what difference that makes.
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    I think you need to get a shorter stem, probably with 7 angle and 50mm length, and a new handlebar with around 30mm rise. If you have spacers above your stem you may not need that much rise on the handlebar or the 7 angle on the stem.
    Check your LBS or your friends to see if they have stems and/or handlebars you can try before you buy new stuff without knowing for sure if it works for you.
    Oct 2019
    Quote Originally Posted by Aglo View Post
    Thanks for your help Aglo, I have found Walter's Bicycle Stem Rise/Reach Calculator & believe if I use an 80m.m. stem with a +30 uprise stem it will lift the bars by 22 m.m. & bring the reach back by 27 m.m.
    Nov 2017
    Do you have any spacers on top of your present stem? If so the easiest thing to try is moving your existing stem up so all the spacers are below it.
    Oct 2019
    Quote Originally Posted by wayold View Post
    Hi Wayold, thank you for your reply. I have 3 spacers on the top of the steerer tube Below the stem & no room for anymore at all.
    Cheers,
    Reputation: Heist30's Avatar
    Apr 2018
    Check out this illustration of the DMR Defy stem...provides 15-20mm rise over a regular stem due to the low profile clamp...
    https://m.youtube.com/watch?v=9oxkX-PW0RA
    Oct 2019
    Thanks for this Heist30.
    Apr 2018
    Backswept bars is another option... Here is a review on a new bar available with 12 or 16 deg angle and up to 45mm rise...
    https://www.bikemag.com/gear/compone...30x-12-degree/
    Oct 2019
    Quote Originally Posted by Heist30 View Post
    That's interesting Heist30 & thanks for your reply. Currently I have moved my saddle forward about 15m.m; given the saddle a bit of a lift at the nose & rotated the bars to get the maximum lift from them. However due to the terrible bushfires all around where I live the air has been so smoky for about 4 weeks & a week ago I chose not to ride until the smoke clears.
    Oct 2019
    Thank you everyone for your valued input. Currently I have moved my saddle forward about 15m.m; given the saddle a bit of a lift at the nose & rotated the bars to get the maximum lift from them. This has certainly improved the situation, by how much I am yet to determine & see if I can live with this long term.
  1. Replies: 1
    Last Post: 09-19-2014, 06:51 PM
  2. Replies: 1
    Last Post: 07-18-2013, 08:24 AM
  3. Slack Head Angle + Steep Seat Angle
    By motard5 in forum All Mountain
    Last Post: 07-25-2012, 06:12 AM
  4. Stem size and angle / 650b-26'er
    By Mike A. in forum 27.5
    Last Post: 02-02-2011, 12:49 AM
  5. Effect of tire size on stem length & angle?
    By The Squeaky Wheel in forum Turner
    Last Post: 07-12-2007, 08:08 PM
Members who have read this thread: 57
