Stem Riser Advice- Mtbr.com
Results 1 to 9 of 9
    Reputation: sawacs's Avatar
    Jun 2020
    Stem Riser Advice
    I have a Trance Pro 29 2 coming in next week and am fairly certain I will need to get a stem riser for my type of riding.
    Any recommendations on brands?
    Jul 2015
    What is the goal you are trying to achieve and why? May be able to help provide more assistance. There are no stem risers on mountain bikes, there are stems,.that have rise, handlebars that have rise and spacers that can go under the stem to raise the stem and bar combo.
    Sent from my Pixel 4 using Tapatalk
    Nov 2013
    Quote Originally Posted by sawacs View Post
    Theres a plethora of good brands of stems. They come in varying lengths and rise. What are you looking for?
    Lightweight? Enve, easton carbons, etc. of the alloys, Renthals are one of lighter.
    Burly, Chromag. RaceFace has a range of decent stems.
    Jun 2020
    Thanks for the replies.
    My goal is to elevate the handlebars a little to achieve a more upright riding position. Most of my riding, for now will be on mostly flat/bumpy roads.
    Cheers!
    Combat Wombat
    Reputation: BrianU's Avatar
    If you are getting the bike from a shop, they should be able to work with you on this.
    Nov 2017
    Easiest way to add cockpit height is to move your stem up toward the top of the spacer stack. The problem is that this is likely to only give you at most a cm or two of rise (depending on how far up the stack you started).
    Next easiest ways are by getting a stem with a higher rise angle than the usual 0-6 degrees. 17 degree rise stems are pretty common and higher rise 25, 35 and even 45 degree stems are available, but tend to add significant weight at the highest rise angles.
    Finally riser handlebars are widely available with rises up to 30mm and less commonly with significantly more.
    With some combination of the above you can get pretty much any rise you want.
    Reputation: MSU Alum's Avatar
    I would just wait, get the bike, then decide.
    As mentioned, there are several ways of raising your position on the bike to be more upright. Spacers, stems with rise, handlebars with rise including rotating the handlebars that come with the bike to see if that helps.
    There's no way anyone but you can tell what works best in your situation.
    Jul 2015
    Quote Originally Posted by MSU Alum View Post
    Yes, hypothesizing about what height is correct before riding is nearly impossible.
    Jun 2020
    Took the bike out today for the test flight and realized I definitely need to raise the handle bars a bit for comfort.
    Cheers!
  1. Riser Handlebars or Stem Riser Adapter?
    By BikesFloat in forum Components
    Last Post: 08-18-2015, 08:34 AM
  2. Replies: 6
    Last Post: 03-05-2014, 11:59 AM
  3. Riser bar vs. riser stem and flat bar
    By xycarp in forum General Discussion
    Last Post: 06-12-2013, 07:35 AM
  4. Replies: 5
    Last Post: 09-01-2011, 10:11 PM
  5. Riser bars or riser stem?
    By Evisr8r in forum Beginner's Corner
    Last Post: 05-04-2006, 09:22 AM
Members who have read this thread: 53
