Specialized 2FO Cliplite Compatability with Crankbrothers Mallet E Pedals?- Mtbr.com
Results 1 to 3 of 3
    I've been a long time SPD user. For the past 3 seasons I've been using a first generation Specialized Rime shoe with the M520 and then the M785 XT Trail pedal without any issues.
    Yesterday I made the switch to Crankbrothers and I also replaced my Rimes with the new 2FO Cliplite since the Rimes are worn out. Since the change, I'm having issues releasing from the pedal. There seems to be a lot more friction between the shoe and pedal, you can actually hear the rubber squeaking against the pedal sometimes.
    Now, I've done the obvious, screwed down the pins into the pedal and installed the shim under the cleat to space it out a bit further from the shoe, but I'm still having issues.
    My guess is that this is a combination of the stickier rubber on the soles (the Slipknot rubber on the 2FOs is definitely stickier than the Vibram on the Rimes) and the increases surface area contact on the pedal.
    Has any one else run this combination and have had the same issues I'm having? What did you do to resolve it?
    Right now I'm thinking of either buying a set of cleats and using the shims that come with them to add a second shim under each cleat or removing the plastic traction pads that go on either side of the spring mechanism. They might be contributing to the friction the most since they have a raised textured patterns to them. I think I could either filed them down or just remove them completely.
    I'm also hoping the more I use the combination they will wear against each other a bit and make it easier to get out. I had 5 or 6 awkward, slow clipped in falls that I haven't had since I first tried clips. Luckily I wasn't on anything technical so it wasn't too bad, but I do want to figures this out so I can have full confidence in being able to get out if I need to on rockier, more technical terrain.
    Reputation: mfa81's Avatar
    have you fixed your contact issues with the cliplite and mallet e pedals?
    Quote Originally Posted by mfa81 View Post
    No. I gave up and went back to Shimano pedals. 6 degree release vs 15 degree. Made a big difference for me.
    Sent from my SM-N910V using Tapatalk
  1. Specialized 2FO Cliplite vs. 5.10 Kestrel - A Review
    By jcc383 in forum Apparel and Protection
    Last Post: 04-21-2017, 09:01 AM
  2. Replies: 7
    Last Post: 06-11-2016, 05:46 PM
  3. Replies: 2
    Last Post: 05-26-2016, 11:02 AM
  4. CrankBrothers Mallet DH Race Pedals used as flats?
    By Harrison Schober in forum Components
    Last Post: 03-21-2016, 12:50 PM
  5. Crankbrothers Mallet for XC?
    By FlowMaster23 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2013, 02:52 PM
