Shimano ST-RS505 2X left disc brake drop bar shifter lever to 3X?- Mtbr.com
    Reputation: Whiptastic's Avatar
    Mar 2016
    Can a Shimano ST-RS505 2X left disc brake drop bar shifter lever be converted to a 3X?
    I have a Sturmey-Archer CS-RK3 3spd IGH cassette hub 27.5 wheelset that I want to use on a Soma Wolverine frame with off-road drop bars. This internal rear hub 3spd works with a standard 3X front derailleur shifter, but the ST-RS505 disc brake set I have is 2X. Id like to use the left lever shifter for 3X if possible.
    Shoot your TV and turn off your CPUs, then get outside and start living!
    Banshee Paradox & Soma Wolverine 3spd Belt Drive
    Mar 2016
    Any mechanics out there know if converting this 2X lever to a 3X lever is a 100% no go?
    Reputation: Lone Rager's Avatar
    Dec 2013
    AFAIK, there is no converting Shimano brifters between 2x and 3x. Some older lower-end left brifters had a switch to go from 2x to 3x, but apparently this one does not. If it did, it'd be shown in the little use manual that comes with it. I believe you're SOL.
    https://si.shimano.com/pdfs/um/UM-07X0A-003-00-ENG.pdf
    Do the math.
    Mar 2016
    Thanks. Dont need it for my current application, but was looking towards the future and its universality between my bikes and wheelsets. Only using the right 11spd with a Tanpan SH11 for a MTB Shimano XT long-cage derailleur 1X11 on current application; left is unused.
  1. Shimano RS505 performance for CX racing
    By wheelzqc in forum Cyclocross
    Last Post: 08-24-2017, 02:27 PM
  2. Older 3x front der. with 2x setup&shifter?
    By RaikkuFIN in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-06-2014, 09:08 AM
  3. Replies: 0
    Last Post: 10-14-2013, 10:59 AM
  4. 2x Shimano SLX Shifters on a 3x Shimano XT crankset?
    By Lemonaid in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-06-2013, 07:34 AM
  5. How do you set up a 3x shifter for a 2x Crank?
    By redweeble1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-29-2011, 10:59 AM
Members who have read this thread: 13
