Shimano SPD pedals squeaking- Mtbr.com
Results 1 to 13 of 13
    Mar 2013
    I searched and came up with a number of threads that didn't really help so I'm starting a new one. I've determined that I'm getting squeaking from where the blue arrow is and the opposite side of the metal of where the red arrow is pointing. If I put some chain lube on a q-tip and get it in there, it's quiet for a bit but then when it attracts grit it's louder than it was before.
    Is there anything I can use that doesn't attract grit? Copper/lithium/teflon grease? I haven't used any of these to know if they're better or worse but thought I'd start here.
    Attached Thumbnails Attached Thumbnails Shimano SPD pedals squeaking-untitled.png
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    blue arrows red arrows wtf
    none of my spuds have colored arrows anywhere
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Mar 2013
    Quote Originally Posted by 127.0.0.1 View Post
    Sorry, I got distracted and forgot to upload the pic.
    Jul 2015
    Throw a but of grease in there I've had to do it before worked fine
    Sent from my Pixel 4 using Tapatalk
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    Squeaky pedals are annoying! Iíve been using this lubricant. Itís more viscous than chain lubes or other general purpose lubes. After a 90 minute ride in dust my pedals are still smooth and silent. I put a couple of drops on the underside of my shoe cleats instead of on the pedals though, simply because it was easier to reach. Itís the part of the cleat that contacts the pedal exactly where your arrows are.
    WPL ForkBoost Fork Seal Lubricant and Cleaner, Biodegradable and Bio-Based, Rubber-Compatible Dust Seal Treatment for Bicycle Forks and Shocks https://www.amazon.com/dp/B07DQHCQVX..._eQ-6EbTESVE0V
    Mar 2013
    Quote Originally Posted by Nat View Post
    Squeaky pedals are annoying! Iíve been using this lubricant. Itís more viscous than chain lubes or other general purpose lubes. After a 90 minute ride in dust my pedals are still smooth and silent. I put a couple of drops on the underside of my shoe cleats instead of on the pedals though, simply because it was easier to reach. Itís the part of the clear that contacts the pedal exactly where your arrows are.
    Are you putting it on every ride?
    Jul 2015
    Normal parktool lube I only had to put on ever few months
    Nat
    Nat is online now
    Quote Originally Posted by Alias530 View Post
    I've only just started using it and I've only needed to apply it once so far.
    Aug 2019
    Same deal. I usually Triflow at the same time as my chain
    Thicc Member
    Reputation: TylerVernon's Avatar
    Nov 2019
    Mine did that when new, but stopped. Maybe polishing the area is the better solution.
    Nat
    Nat is online now
    Quote Originally Posted by TylerVernon View Post
    The contact area is the underside of the metal bail and would be a tricky area to get to if you wanted to polish it. Dremel tool with a long polishing bit maybe?
    Mar 2013
    That's funny as mine was silent when new and developed the noise later.
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    The squeak is likely worn cleats. Probably only on one side too....
    Todd :thumbsup:
  1. SPD pedals (XT) squeaking, where to lube?
    By Alias530 in forum Components
    Last Post: 04-09-2020, 11:17 AM
  2. SPD pedals squeaking badly
    Last Post: 06-03-2015, 06:41 AM
  3. SPD pedals/cleats squeaking?
    By Alias530 in forum General Discussion
    Last Post: 02-14-2015, 02:02 PM
  4. SPD cleats are SPD cleats are SPD cleats or are they?
    By far raider in forum General Discussion
    Last Post: 11-03-2012, 12:49 PM
  5. Slayer 50 Squeaking, Squeaking !!!!!!
    By demarp in forum Rocky Mountain
    Last Post: 07-07-2006, 06:58 AM
Members who have read this thread: 67
