Seatpost compliance.- Mtbr.com
    May 2018
    So Iím building up a new titanium hardtail. Iím trying to decide between an ENVE seatpost or a syntace hiflex. Will I notice any difference between the two posts? The frame supplier is offering either one free of charge, so I thought Iíd ask. Leaning towards the syntace because itís actually designed to flex a bit.
    It's been a few years since I've ridden a Enve( they could have changed the layup)....but the Syntace was noticeably softer riding (in a good way).
    But...it also matters how much seatpost is exposed. On my mtb with a 19" seat tube....rides much softer than a bike with 4 inches less seatpost exposed.
    I run Syntace on most of my hardtails.
    May 2018
    Quote Originally Posted by the mayor View Post
    There will be almost all of the 400 mm post exposed, maybe a cm of wiggle from the lowest insertion point. But itís 30.9, so I was worried it might not matter too much which post I choose. Thanks for the feedback!
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by Dromos123 View Post
    That's a red flag, there's a good chance over time you'll crack the frame with that much exposed seatpost, especially given the nature of Ti welds. Although you might have significantly more than the "min insert", that just means you won't break the seatpost, but that much exposed seatpost makes a huge lever on the frame and can be a huge issue. I have broken a frame due to this, even with massive insertion depth. You should talk to the frame builder about this and see if they think it'll work.
  1. 31.6 seatpost compliance
    By fordohio in forum 29er Components
    Last Post: 09-11-2012, 11:36 AM
  2. chromoly riser bar = compliance/comfort ?
    By phoenixbikes in forum Weight Weenies
    Last Post: 12-06-2011, 11:55 PM
  3. Float - small bump compliance and fr/dh compatability?
    By drastic. in forum Downhill - Freeride
    Last Post: 08-14-2011, 06:57 AM
  4. Replies: 12
    Last Post: 06-15-2011, 03:12 AM
  5. How much compliance in a "rigid" Ti bike?
    By JimInSF in forum 29er Bikes
    Last Post: 01-12-2011, 05:23 PM
Members who have read this thread: 7
