Saddles and droppers that move the saddle forward- Mtbr.com
Results 1 to 2 of 2
    EXORCIZE
    Reputation: Ryder1's Avatar
    Beyond slamming your saddle forward on a straight post, what other options exist? Long saddle noses can be helpful but who wants to camp out up there? A saddle with tall stack makes no real difference. Geo changes are cheating. That leaves:
    [1] Saddles with rails extending further rearward (relative to saddle) than usual (e.g. Fizik Thar). Any others? They all look very similar to me.
    [2] 9point8 droppers have optional offset heads (+/- 25mm) AND you can swap them on the same post - nice! Any other droppers offering forward offset or reversible offset?
    Jun 2016
    I have a very similar question, with the difference that I had already done some change.
    I use the Raceface Aeffect dropper, that has a sort of a bracket to adjust saddle inclination. If you look at that bracket, it is asymmetric in the front/rear direction:
    https://www.raceface.com/products/de...effect-dropper
    So I inverted the bracket, that moved the saddle about 15-20mm forward:
    There's nothing in the Raceface literature that mentions that this should be done. Visually seems ok, as my weight still seems to be applied to close to the center of the dropper. However I don't know if this would damage the dropper in the long term.
    Sorry to confuse more than explain, but that above quite solved my problem. Now the question is if this will case problems in the future.
    Attached Thumbnails Attached Thumbnails Saddles and droppers that move the saddle forward-img_20190519_125634.jpg
  1. Saddles that allow more forward positioning?
    By pakcyclist in forum Components
    Last Post: 01-24-2016, 07:28 PM
  2. anatomic saddles and only anatomic saddles............
    By charliethetuna in forum Clydesdales/Tall Riders
    Last Post: 02-27-2015, 12:28 PM
  3. Quads failing/cramping before all other groups - move saddle forward?
    By OldZaskar in forum XC Racing and Training
    Last Post: 03-12-2013, 01:07 PM
  4. Saddles Saddles and more Saddles
    By Anarchy_Biker in forum Endurance XC Racing
    Last Post: 01-20-2006, 09:48 AM
  5. Saddles, saddles, what saddle??
    By evo5 in forum General Discussion
    Last Post: 01-12-2005, 11:07 AM
Members who have read this thread: 23
