Rockshox Reverb Stealth bleed question- Mtbr.com
    Jul 2019
    Hi All,
    Looking for help/solutions.
    I just ordered and recieved a Rockshox hydraulic bleed kit for a Rockshox reverb stealth, (I think b1).
    However, i just noticed after fluffing around that you need a "special" bleeding edge tool for the stealth remote (BS). So i can't actually undo the bleed screw.Anyway around this?
    This was an dropper post i immediately took off a new bike so i never used it. I put it aside for a few months and it doesn't actuate at all so i imagine i just need to add fluid firstly.
    any help would be appreciated!
    Jun 2013
    Umm did you check the air pressure? Because if it's low on pressure then it won't move. The bleed kit should come with two syringes; one attaches at the post head and the other at the remote so I don't know what you mean where you didn't get all the tools if you got the kit.
    Jul 2019
    sram has a proprietary bleed tool for the lever called bleeding edge tool. I didn't realize the switched to it for rockshox stealth remote. that's the tool im missing
    Reputation: Lone Rager's Avatar
    Dec 2013
    If you have the 1x remote with the paddle, you need the bleeding edge tool. When you buy a new Reverb, you get the complete bleed kit and fluid with it so should be all set.
    The kit and bleeding edge adapter are specific to mineral oil, which is used for the remote. The brake bleed kits are different as they use DOT. The push-button plunger type of remote uses standard threaded bleed fittings, but still mineral oil specific.
    I got a deal on a oem post without packaging that did not come with the kit. It cost less than 1/2 of a new post. Fortunately I already had the bleed kit.
    IMO, a hydraulic remote for a dropper is silly and a pain in the butt compared to a decent cable setup. There are a couple of kits that convert Reverbs to cable actuation if you want to go that route.
    What, me worry?
  1. Replies: 6
    Last Post: 08-03-2017, 04:19 PM
  2. Rockshox Reverb stealth question
    By RobD22 in forum Components
    Last Post: 03-30-2017, 10:48 AM
  3. Replies: 0
    Last Post: 11-13-2015, 02:41 PM
  4. Rock Shox Reverb / Reverb Stealth
    By WorldIRC in forum Trek
    Last Post: 07-01-2013, 07:12 PM
  5. Reverb Stealth Bleed insanity
    By rodeoj in forum Shocks and Suspension
    Last Post: 06-24-2013, 06:50 AM
Members who have read this thread: 17
