pedal problem - cleat/pedal play- Mtbr.com
Results 1 to 5 of 5
    Apr 2013
    My shoes wore out totally, so i got a new pair of shoes. Moved the cleats from the old shoes to the new ones and now they are floating around way too much. What would cause this.
    its the same cleats and pedals. just new shoes.
    all are Shimano. pedals xt, shoes, and cleats.
    the cleats are screwed in tight, they aren't slipping. they are just floating too much while clipped in. i did not change the release tension.
    i also took care to make sure the cleat that was on the old left shoe went on the new left shoe. thanks
    Reputation: sturge's Avatar
    If old cleats are properly secured in new shoes and nothing between cleat and pedal has been messed with, it's got to be the shoes. Is the sole/base of the shoe where cleats are attached thinner or less robust than your old shoes? Maybe the cleat mount/shoe sole interface is more flexible and that's what you are feeling?
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...:thumbsup:
    Apr 2013
    i don't think its more flexible. it seem stiff and is basically the same model of shoe, just newer.
    i do think maybe the cleat box area is less deep, so the cleat sits higher. when it is clipped in there is a slight gap between teh platform portion of the pedal and the bottm of the shoe.
    any fix for that?
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    If the sole of the previous shoe was contacting the pedal and reducing/interfering with what would have been float...did you put the cleats in the same location on the new shoes? Could be a matter of a mm or 2.
    :nono: :thumbsup:
    Apr 2013
    i tried to get them in the same location. for/aft left/right
  1. Pedal / Cleat compatibility
    By SpringsRubicon in forum General Discussion
    Last Post: 11-30-2012, 05:10 PM
  2. Shimano M424 pedal and cleat problem??
    By Trail Addict in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-06-2012, 05:24 PM
  3. Shimano M424 pedal and cleat problem??
    By Trail Addict in forum Shimano
    Last Post: 04-06-2012, 09:24 AM
  4. spd pedal/cleat compatibility
    By package81 in forum General Discussion
    Last Post: 09-07-2011, 10:55 AM
  5. Time Atac: play in cleat/pedal connection
    By AdamW in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-30-2005, 09:54 PM
Members who have read this thread: 21
