Oneup dropper help- Mtbr.com
Results 1 to 3 of 3
    Jan 2015
    Oneup dropper help
    Installed my post but it sinks about an inch into the travel when I put weigh on the seat. Anyone have this issue? Cable tension adjustment doesnít solve it. I noticed that the white bushing under the collar does not seat all the way into the post, it sticks up about half way out. Could that be the problem?
    Jan 2015
    Iíll answer my own question in case anyone else has this problem. The post was shoved too far down in the seat tube, which I think was partially actuating the post causing the sinkage. Moved the post up slightly and itís solid now.
    Reputation: OneUp's Avatar
    Nov 2013
    Quote Originally Posted by Samo831 View Post
    First, the white bushing should definately not stick out halfway. Note that the the post needs to be at least 20mm into its travel before you attempt to push the white bushing in.
    Once that is done the and the top cap is fully installed completely disconnect the remote and check for sag. If there is sag, with no cable attached, contact [email protected] for warranty. We stand behind our products 100%.
    I hope this helps,
    Jon @ OneUp
  1. OneUp dropper post
    By RS VR6 in forum Components
    Last Post: 10-07-2019, 10:24 PM
  2. Replies: 2
    Last Post: 03-27-2019, 01:29 PM
  3. FS: brand new OneUp dropper post
    By stripes in forum Classifieds
    Last Post: 08-27-2018, 05:17 PM
  4. OneUp dropper post
    By fc in forum California - Norcal
    Last Post: 05-20-2018, 09:55 PM
  5. PNW Bachelor or OneUp Dropper post?
    By jgusta in forum Components
    Last Post: 05-19-2018, 09:36 PM
Members who have read this thread: 34
