moving GX shifter over towards stem?- Mtbr.com
    Sep 2018
    I have a GX shifter attached directly to my brake lever. It's attached with a torx bolt and right next to the bolt is another small recessed bolt. Can I remove that small recessed bolt and swap them to move the shifter over to the left? I keep hitting my thumb on the shifter and it would free up a lot of space if i can move it over while keeping the brake lever in its current position.
    Attached Thumbnails Attached Thumbnails moving GX shifter over towards stem?-img_6273.jpg
    Reputation: Lone Rager's Avatar
    Dec 2013
    Yes. That's the purpose of the second hole, to move the shifter relative to the brake. Personally, I use separate mounts for the shifter and brake. It's simpler to deal with and more adjustable.
    What, me worry?
    HHL
    HHL is offline
    Que je suis bete!
    I agree with Lone Rager. I have never found a good combo of feel on the bars with the shifter mounted to the brake hardware. Buy the mounting ring for the shifter, put everything exactly where you want it and be done with it. The rings are a little pricey, but worth it.
    Dec 2013
    Likely your LBS has the mounting rings lying around as they come with the shifter and get tossed in the junk drawer when installing a shifter on the brake mount. Depends on the LBS and your relationship as to whether or how much they'd charge for it or not.
    What, me worry?
  1. SRam GX Eagle VS GX Eagle DUB VS SRam GX 1400
    By lqbweb in forum Components
    Last Post: 04-13-2018, 02:10 AM
  2. Replies: 5
    Last Post: 10-10-2017, 02:07 AM
  3. SRAM GX 10 vs GX 11
    By Ricanfred in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-29-2016, 02:47 PM
  4. Sram x5 rear shifter vs gx rear shifter?
    By d4nt3ch in forum SRAM
    Last Post: 09-26-2015, 02:07 PM
  5. Input needed! moving towards a bigga gal 26->29
    By Johan14 in forum 29er Bikes
    Last Post: 10-27-2008, 10:50 AM
Members who have read this thread: 24
