Mismatched headset cups/bearings a problem?- Mtbr.com
    I have FSA zs56/zs44 cups in my frame and dropped new Cane Creek bearings in but now the fork binds with even a small amount of tension on the pre load bolt. The clearance on the top cap is still around 3mm. I canít think what it could be other than the cups?
    Thanks in advance for any help.
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Try to remove the top cap, install a stem spacer instead of the top cap, apply some preload and see it it binds.
    When mismatching headset components even the seals may cause interference.
    Reputation: RS VR6's Avatar
    Quote Originally Posted by Imho4ep View Post
    Some of the bearings have different angles and will not seat properly into another manufacturers cup. I tried something similar with a Cane Creek and a Banshee headset (not sure who made the headset). The bearing would not fit properly in the Banshee cup. I had to remove the cup and use the Cane Creek one.
    Your best but is to punch out the existing cup and press in a CC one.
    Quote Originally Posted by RS VR6 View Post
    Yup this was the problem, works great with the proper cups. Thank you!
  1. headset seal for big headset cups
    By mack_turtle in forum Components
    Last Post: 10-15-2018, 02:33 PM
  2. Mismatched brakes - 4 piston front?
    By Phil_T in forum Santa Cruz
    Last Post: 07-31-2011, 07:55 AM
  3. Replies: 7
    Last Post: 02-23-2008, 11:30 AM
  4. Reducer cups or no reducer cups?
    By MattP. in forum Downhill - Freeride
    Last Post: 11-09-2006, 08:15 PM
  5. HollowTechII XT BB cups = XTR BB Cups?
    By psychojylo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-30-2004, 10:50 AM
