Just bought a Carbon Seatpost - Installation questions and should I be worried?- Mtbr.com
Results 1 to 9 of 9
    May 2015
    I recently upgraded the seatpost on my Marin Rift Zone to a Thomson Elite. However, the setup was not ideal as I had to buy a longer bolt to get the seatpost level due to angle of the seat-tube. Also, the zero setback of the Elite was not ideal.
    So I stumbled across a great deal on an Answer SL carbon 20mm setback post. I'd previously sworn off carbon posts after reading a few horror stories about them, but I decided to purchase it anyway.
    So my first question is how many of you have been riding a carbon seatpost (name brand and with correct torque setting) for a decent amount of time without breaking one?
    Onto the installation: I've read several recommendations to always use carbon fiber paste, but also read recommendations to install dry. For the record, I'm installing the carbon post into an aluminum frame. The saddle rail guides are also carbon. What's the consensus on the use of carbon paste and would I also need to use for the saddle attachment?
    Lastly, the Answer post came with a lock on collar - I'm assuming this is to stop any slippage, but is it really needed?
    Jan 2016
    I would not use paste UNLESS the post slipped after being torqued------I had one seize in a frame and it took the mfg to get it back out-was carbon to carbon-I also these days loosen the post every few months just to make sure----I simply want to avoid the situation again----I also ride on the road where many use carbon posts and while not a typical topic have not heard of anyone using paste.
    May 2015
    Thanks pctloper - how long have you been riding with a carbon post on your mountain bike?
    Jun 2016
    AFAIK the carbon paste is also anti-seize, so I don't see why not use, as long as you use good quality. I use a blister from Giant, that I got for free from my LBS. since I use so little every time I assemble anything, a single blister can be used for many assemblies.
    Having that said, I have a carbon seatpost on my road bike only, and the slippage ruined the finishing of the seatpost. Whish I had used carbon paste from the beginning.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    I've been using an easton EC90 20mm setback road bike post on my hardtail for 4 years and 3 drivetrains now, no issues.
    torque yes (a) seat anchor wedge (giant XTC frame) torqued to Giant specs (10.2nm) and (b) seat rail anchors torqued to Easton specs (5nm)
    no problems, and post does have a wee bit of flex if you twist on it to check if it flexes. I lathered it in TACX carbon paste for install. I applied a strip of 'watch tape' across the post/seat tube interface to see if the post sinks at any time, it never budges, ever.
    same deal as the answer post, -all carbon- except the bolts and nuts
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    May 2015
    Quote Originally Posted by 127.0.0.1 View Post
    Did you use carbon paste on the saddle interface parts too?
    Reputation: Lone Rager's Avatar
    Dec 2013
    Always paste a CF post and grease a metal post. No paste on rails, though I do grease them, CF or metal.
    Yes. If it's carbon, worry. Besides strength, lightweight and tuneable flexibility, worry is one of the major consequential attributes of carbon.
    Do the math.
    EAT MORE GRIME
    Nov 2013
    Quote Originally Posted by mcbiko View Post
    no, the rails are alcohol cleaned and metal rail to carbon, no paste. no creaks.
    full disclosure it's this saddle on that post, manganese rails
    Selle Italia C2 Gel Flow Saddle
    Just bought a Carbon Seatpost - Installation questions and should I be worried?-selleitalia.jpg
    May 2015
    Alright, just finished installing. Cleaned the rails with isopropyl alcohol and installed saddle with no paste or grease - torqued to 4NM (max spec is 5NM). Cleaned inside seat-tube with alcohol, applied Fiber Grip paste to section of seatpost inside seat-tube, and torqued to the same 4NM. Hopefully this is enough to hold - I've put a piece of tape on the post so I can keep track of any slippage.
    I left off the extra collar that came with the post shown in this link https://www.amazon.com/Answer-Produc.../dp/B017P3L0J4
    Or should I still install the collar - I'm guessing its designed as an extra anti-slip mechanism?
  1. Should I be worried? (neck injury)
    By Dudeus in forum Rider Down, injuries and recovery
    Last Post: 03-26-2011, 04:53 PM
  2. Should I be worried? Bent/warped spokes...
    By Ratman in forum Wheels and Tires
    Last Post: 02-19-2011, 01:23 PM
  3. Air 9 Chainstay -- Should I be worried?
    By quelocotony in forum 29er Bikes
    Last Post: 01-10-2011, 09:57 AM
  4. Bought some hope m4, now worried they wont fit.
    By cajunjay in forum Brake Time
    Last Post: 07-17-2007, 05:24 PM
  5. Replies: 15
    Last Post: 04-03-2006, 05:46 AM
Members who have read this thread: 9
