Integrated Headset Frame - Zero Offset Headset- Mtbr.com
Results 1 to 5 of 5
    BrassBalled DropbarNinja
    Reputation: mrpercussive's Avatar
    Hi guys, just realized my new frame has an integrated headset but this idiot ordered an inset headset by accident... What are the chances that I'd be able to just pop the bearings in there with no issues? Thanks!
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Just check the bearings sizes and compare to the old bearings.
    Chances are you won't find any problems on just dropping the bearings in.
    Quote Originally Posted by Aglo View Post
    just looked it up... turns out i'm good on the bottom but the top is apparently an IS42 and the inset headset I got is a 41mm bearing... FML
    Reputation: Lone Rager's Avatar
    Dec 2013
    I always confirm the ID, OD, height and inner and outer seat angles to be sure.
    Do the math.
    Jun 2016
    Quote Originally Posted by Lone Rager View Post
    Out of curiosity, have you ever seen different angles? I heard they exist, but never seen any different than mine. At least not visually different.
  1. Replies: 3
    Last Post: 09-06-2012, 05:46 PM
  2. Difference between offset and zero offset seatpost
    By D3NN15M in forum Beginner's Corner
    Last Post: 06-28-2011, 07:39 PM
  3. Replies: 2
    Last Post: 06-03-2011, 02:39 PM
  4. '04 topanga headset. zero stack or integrated??
    By jgsatl in forum Diamondback
    Last Post: 10-10-2006, 05:05 PM
  5. Headset question... Zero Stack or Integrated..
    By mattsavage in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-24-2005, 10:53 AM
Members who have read this thread: 22
