Installing Dropper for the First Time. Cable Routing?- Mtbr.com
Results 1 to 3 of 3
    Nov 2014
    2016 Raeigh Skarn Pro 27.2mm Seatpost (410mm), 1x
    Would prefer inner cable routing.
    I have a port on upper left near headset. Would putting lever on L/S be ok? I know not ideal
    Will cable make a good enough bend near BB?
    I am looking at Wiggle's Brand-X w/105mm drop, I would need to buy shifter style lever.
    https://www.wiggle.com/brand-x-ascen...pper-seatpost/
    Any other input appreciated.
    Attached Thumbnails Attached Thumbnails Installing Dropper for the First Time. Cable Routing?-img_7112.jpg
    Reputation: Lone Rager's Avatar
    Dec 2013
    If there is no port for a dropper cable in the seat tube you have no choice but to run it internally. Fishing it through the bottom bracket area can be a bit tricky. The Park tool internal routing kit can be used, or something similar jury rigged. With the Park tool, you put one cable with a magnet down the downtube and the mating cable and magnet down the seat tube and try to get them to hook up. The magnets tend to stick to ferrous metal parts/screws along the way (particularly a steel crank spindle) so it can take some finagling and use of an external magnet to help guide things. In some cases it may be quicker/easier to gain access by removing the BB.
    Do the math.
    Aug 2019
    For internal routing, this tool comes in handy.
  1. Help: installing dropper trigger cable
    By singletrackmack in forum Components
    Last Post: 12-15-2016, 08:12 PM
  2. Replies: 8
    Last Post: 09-14-2015, 11:30 AM
  3. Installing A11 into 29er: cable routing
    By Erichimedes in forum Internal Gear Hubs
    Last Post: 01-15-2015, 10:54 AM
  4. Tall boy dropper seatpost cable routing issue
    By C & D's Dad in forum Santa Cruz
    Last Post: 06-11-2011, 02:27 PM
  5. Custom cable routing for dropper seatpost?
    By D45yth in forum Nicolai
    Last Post: 01-06-2011, 01:58 AM
Members who have read this thread: 29
