Headset too tight?- Mtbr.com
Results 1 to 11 of 11
    Sep 2018
    Headset too tight?
    So I can't seem to dial in my headset properly. At first it was a little loose so nipped the top cap up. Now it's too tight. I've tried all manner of the spacers here to try and sort it. Just feels like I can never get it right. Either has play or is too tight.
    Have watched quite a few videos to see if I'm doing it wrong but have followed all guides.
    Really want to get back out riding if anyone can help me.
    Dec 2017
    This is something you do by feel. If there's an actual spec for bearing preload, I've never read it, never used it, and I have no apologies about doing so. The amount of stress on a headset is so minimal, that I would just say make sure that the cups are bottomed out in the frame, that you're using the right parts to begin with, snug it up, tighten your stem, and call it a day. Don't over think it.
    Sep 2018
    Quote Originally Posted by twodownzero View Post
    Yep it's just that when everything is snug it's just too tight. If I pick the bike up the handlebars don't move when I tip the bike.
    Everything seems to be in it's correct place according to all the guides I've read. For some reason it's not a sealed headset bearing like I thought it would be so wondering if that is the issue?
    Nov 2006
    Does it feel rough or hard to turn after snugging it up? Cable tension may be a factor in why it doesn't move when you tip the bike.
    In addition, if it feels like there is play when you think it is loose, make sure and check that any play you feel is the headset and not the fork moving slightly at the seals. New bike? Or are you replacing bearings in an used bike?
    Oct 2018
    Are you loosening the stem bolts before making adjustments?
    Set the preload to what you think is correct.
    Wrap your hand around the head tube so you have a finger or two on the stem. Pull the front brake lever and rock the bike forward and back -is there play?
    If yes, tighten a tad and repeat the rocking procedure.
    If no, lift the bike and turn the bars back and forth. Is it stiff or feel crunchy?
    If yes it feels stiff, loosen a tad.
    When doing fine tuning at this point, the amount you turn the screw is very limited. Don't think of it like tightening your brake clamp to where you turn it enough to make it snug. Bearing preload is a much more fine procedure.
    It's tedious, loosen stem bolts. Set bearing preload. Align bars and tighten stem bolts (because we assume we got the bearing set properly the first try).
    Repeat until satisfied.
    Just remember to make small adjustments to the top bolt at at a time.
    Could your bearings be worn? Pretty difficult to set preload if bearings are worn out.
    Reputation: J.B. Weld's Avatar
    Sounds to me like there's something wrong with the headset, it's easy to install a seal upside down or put a bearing or spacer in wrong.
    I brake for stinkbugs
    Reputation: Lone Rager's Avatar
    Dec 2013
    I'm guessing something is binding, maybe the headset cap against the headtube of the bike. It could be due to incorrect installation or parts, missing parts, or just needing a spacer or shim.
    How did your arrive in this situation? Are you installing a new headset, new fork, servicing and existing headset, replacing the fork after getting it serviced...?
    Do the math.
    Jul 2015
    As the previous poster asked...Are you loosening the stem bolts before making adjustments?
    Also, the bars don't need to fall to the side on their own when you lift the bike, it just needs to be tight enough that you don't feel resistance when you turn, cables could prevent bars from free falling...
    Sent from my XT1585 using Tapatalk
    Aug 2014
    I'm in the same boat here. I've installed my new headset, second actually as I couldn't get the first one to snug up. I'm confident its the right headset, od and id all match and i used cane creeks website to get a size and bought a syncros (scott bike) headset. The previous cheap headset i was able to snug it up nice and tight but if i backed it off any it would have play. It seemed either too tight or too loose. I mixed up spacers, old part with new part and shims and couldn't get it right. So i figured a better headset might work. Now i can't even get it too tight. What am i missing? I have a spacer, bottom cup and then bottom press fit bearnig. on the top, press fit bearing, spacer, top cap.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Some of the fork races look "upside down" when they are inserted right-side-up, causing some people to install them upside down.
    Aug 2014
    i could see that happening, i feel i got mine right
  1. How tight is too tight.....seat post clamp?
    By rsolti13 in forum 29er Components
    Last Post: 07-24-2012, 07:17 AM
  2. Chain tension - how tight is too tight?
    By djork in forum Singlespeed
    Last Post: 10-14-2011, 04:02 PM
  3. Chain Tension - How tight is too tight?
    By Sarasota in forum Singlespeed
    Last Post: 09-05-2011, 12:11 AM
  4. how tight is too tight for the chain ?
    By bt in forum Singlespeed
    Last Post: 03-15-2011, 10:30 AM
  5. Tire clearance..how tight is too tight?
    By morandi in forum 29er Bikes
    Last Post: 01-14-2011, 10:28 AM
Members who have read this thread: 77
