GX crank arm removal?- Mtbr.com
Results 1 to 3 of 3
    Sep 2018
    I'm trying to remove my GX cranks. The pinch bolt is on the drive side. If I remove that pinch bolt i won't be able to slide the spindle out of the bike because the sprocket attachment bolts are on the inside of the bike covered by the bottom bracket. How do I remove the cranks?
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by shovelheadjoe View Post
    It should be a self extracting 8mm bolt on the drive side crank. Just unscrew it. The chainring is attached to the DS crank and comes off with it.
    (FYI that crank doesn't have pinch bolts)
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Sep 2018
    Thanks, I got it. it was really stuck on there. I
  1. Using X9 left arm on GX Eagle Crank
    By offpiste.reese in forum Components
    Last Post: 11-11-2019, 11:00 PM
  2. Using X9 left arm on GX Eagle Crank
    By offpiste.reese in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-11-2019, 10:55 AM
  3. GX Eagle Crank Arm Stuck
    By msedly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-15-2019, 01:35 AM
  4. SRam GX Eagle VS GX Eagle DUB VS SRam GX 1400
    By lqbweb in forum Components
    Last Post: 04-13-2018, 02:10 AM
  5. Race Evolve XC Crank Arm Removal w/o One-Key Crank Bolt?
    By three.ten in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-13-2008, 01:02 PM
Members who have read this thread: 24
