Grips- Mtbr.com
Results 1 to 7 of 7
Thread: Grips
    Mar 2017
    Grips
    So, I ride and Diamondback mission 2 for my enduro bike and a budget friendly hardtail that I am going to start racing for cross country. On both bikes I have recently been having finger cramps and my hands becomes super numb. I looked into esi, wolf tooth, and Ritchey but I donít know what will help because I donít know if anyone else has cramps like me. I see that foam grips help but durability doesnít seem to good. Any have any recommendations?
    Jun 2016
    I don't know if the cramps I have are like yours, but I have cramps once in a while. This have greatly improved by using good gloves (if there's a seam between your thumb and palm, forget them) and foam grips. These grips (I use Wolf Tooth Fat Paw) will tear a little bit more on crashes, but other than that, they're fine.
    If you want to spend some extra, put carbon handlebars, that absorb a lot of vibration. Alternatively, I use Spanks handlebars, that are aluminum with a foam insert, that are said to dampen a lot of vibration too.
    Reputation: fredcook's Avatar
    When I experience hand numbness, it's due to riding position. Changing grips never resolves numbness (for me).
    You didn't quit riding because you're old, you're old because you quit riding.
    Mar 2017
    Quote Originally Posted by fredcook View Post
    What did you do to reduce the numbness?
    Short-Change-Hero
    Reputation: gregnash's Avatar
    This... also has to do with proper suspension setup. Riding too far forward (putting excess weight on your hands/shoulders) will cause numbness.
    Jun 2016
    In a way, yes. If you don't put weight on the handlebar anytime, correct. But when I'm tired, I put weight, and then bad gloves and bad grips makes matter worse.
    May 2018
    I had a lot of success with SQ Labs 7OX grips but they didn't even last a whole season. I'm planning on getting another pair of 711s (more rubber) to see how they go.
    Also looking into my handlebar setup. Currently I have a 35mm clamp aluminum bar and stem. Wider bar is stiffer, transmits more vibration. Planning on getting a 31.8 mm bar/stem. Spank Vibrocore.
  1. Grips grips grips
    By JLDickmon in forum Clydesdales/Tall Riders
    Last Post: 06-20-2018, 11:43 AM
  2. Ergon GS1 MTB Racing Grips or Specialized Contour XC grips
    By marcos77 in forum General Discussion
    Last Post: 01-28-2014, 07:41 PM
  3. Imprint Grips - Custom Moldable Lock In Grips on Kickstarter
    By NoTryOnlyDo in forum General Discussion
    Last Post: 12-16-2013, 09:45 AM
  4. What's not a good idea? Installing grips like golf grips
    By boo radley in forum General Discussion
    Last Post: 11-20-2013, 05:12 PM
  5. soft grips vs. hard grips?
    By shwinn8 in forum Downhill - Freeride
    Last Post: 11-03-2011, 09:46 AM
Members who have read this thread: 64
