Garmin Mount- Mtbr.com
Results 1 to 15 of 15
Thread: Garmin Mount
    Jul 2019
    Garmin Mount
    What do people prefer for their Garmin mounts? is there a reason that MTB ones tend to be on or over the stem? Anything out there that feels a bit higher quality vs standard plastic ones?
    (70mm stem on a full suspension bike, if that makes a difference)
    What about the combo mounts for a camera or light as well? Those would need to be out front, right?
    Oct 2018
    Humm, not sure why my original reply isn't showing up.
    There are a few preferred.
    The out front mount isn't too preferred as it's more prone to taking a hit. There is a road bike version (long) and MTB option (shorter). The MTB out front mount can be installed backward so it sits over top of the stem, less likely to take a hit.
    The O-Rings are used by some. Some purchase a top cap mount, but you need to add a 5mm spacer to top of the stem for this to work.
    Some people even mount it to the top tube for some reason.
    Look in the GPS forum, you'll find more results. A Garmin device isn't a component.
    Jul 2019
    Thanks for the reply, I was trying to find the right topic to post this in. Is it possible for a mod to move it over?
    Reputation: RS VR6's Avatar
    I like them on top of the stem best. I've pretty much tried them all.
    Attached Thumbnails Attached Thumbnails Garmin Mount-img_20180318_190442_hht.jpg
    Reputation: Mudguard's Avatar
    I have mine mounted in place of the steerer cap. I've only knocked it off once.
    Jun 2016
    I used to like exactly the standard plastic one, that mounts with rubber bands on the handlebar. They are far enough from my body and they rotate around the bar in case of crash.
    The aluminum support for garmin and flashlight/camera works good for road, but I don't like it much for MTB. Too rigid, and will likely break my equipment before breaking themselves.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Quote Originally Posted by fmendes View Post
    ...The aluminum support ...too rigid, and will likely break my equipment before breaking themselves.
    Yeah. For some applications, plastic is better. I use a Barfly plastic mount to position the Garmin behind the bar, tightened just enough to keep it from rotating around the bar on it's own, but loose enough that it'll move easily when hit protecting the Garmin. Also, the plastic won't dig in or damage carbon bars in a crash
    Do the math.
    Reputation: mfa81's Avatar
    I've been trying to find some reliable toptube mount since forever and haven't been able to yet. What I do is the standard quarter turn mount and rubber rings and use a ziptie to connect the rubber under the top tube, not pretty but works. wish garmin made extra long rubber rings.
    chasing simplicity
    Reputation: MattMay's Avatar
    Dec 2013
    K Edge makes a number of different top tube mounts. They replace a 5mm spacer.
    Never underestimate an old man with a mountain bike.
    Oct 2018
    Quote Originally Posted by mfa81 View Post
    Quote Originally Posted by MattMay View Post
    Top tube or top cap?
    Sounds like MFA is referring to the bicycle top tube and MattMay is referring to "top of the stem".
    The insert can be removed from a K Edge mount. You can always try and use some double sided tape (the 3M stuff. If it can hold a spoiler to a car...why not a Gamin?) or some other creative way to mount it to the top tube. I would definitely use a leash for the Garmin if you're trying to experiment.
    Garmin Mount
    hereís how I have now
    I saw this on ews youtube video but couldnít figure put what it is
    itís on leigh johnsonís Pole, looks some dual side 3m thing like suggested
    chasing simplicity
    Dec 2013
    Quote Originally Posted by Forest Rider View Post
    Apologies, top cap on fork. My bad.
    Sep 2017
    The adhesive Garmin mount is 3d printed by 76Projects and for sale on their site.
    https://www.76projects.com/shop/51vz...rt1krtj7-xena5
    Quote Originally Posted by mnpikey View Post
    Thank you! that's what I needed :-)
  1. Creating Garmin TCX Courses from Strava GPX in Garmin Connect
    By canuck_tacoma in forum GPS, HRM and Bike Computer
    Last Post: 08-14-2013, 08:50 PM
  2. Garmin 500 & Garmin External Power Pack test
    By xxxxx in forum GPS, HRM and Bike Computer
    Last Post: 04-02-2013, 06:17 PM
  3. Garmin 800-Use Elevation Correction on Garmin Connect?
    By nevermiss in forum GPS, HRM and Bike Computer
    Last Post: 03-15-2012, 01:05 PM
  4. Garmin Connect or Garmin Training Center elevations
    By wvmtb in forum GPS, HRM and Bike Computer
    Last Post: 06-17-2011, 06:59 AM
  5. Garmin software and Garmin GPS Not talking.
    By crux in forum GPS, HRM and Bike Computer
    Last Post: 01-01-2011, 11:44 AM
Members who have read this thread: 57
