front fender mount- Mtbr.com
Results 1 to 8 of 8
    Oct 2013
    front fender mount
    I'm tired of having a wet face from the tire spraying water. I want to add a front fender so I was wondering if it can be mounted like this below.
    What would be the best route to go? Use JB weld or epoxy to fasten a nut in the space on the shocks or drill a hole and tap it?
    Attached Thumbnails Attached Thumbnails front fender mount-img_20191009_200954.jpg
    Aug 2019
    Humm, I'm no structural engineer but I'm thinking drilling a hole in your lower arch will be introducing a failure point later down the road.
    Why not pickup one of those inexpensive flexible mud guards that you attach using zip ties?
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Agree with the suggestion to buy a zip tie fender. It may be that there is little to no load on that arch, but why would you ever take a drill to a fork?
    2020 Kona Unit
    2019 Forbidden Druid
    2018 Kona Honzo ST 30th BDay SE
    2015 Kona Paddy Wagon Fixed Gear
    Reputation: ColinL's Avatar
    Feb 2012
    Even if it doesn't fail, a hole will certainly introduce flex. That arch is braced for a reason..
    If you don't have the tire clearance for a fender zip tied inside the arch, I'm sure there are better alternatives to this solution.
    Sent from my Pixel 3 XL using Tapatalk
    Reputation: fredcook's Avatar
    I would vote for not drilling a hole in the arch.
    You didn't quit riding because you're old, you're old because you quit riding.
    Oct 2013
    So either buy a zip tie fender or use JB weld and glue that nut in there.
    I think JB welding or some other sort of export to hold that but there is a great idea. The less zip ties the better imo. You know what we really need is a new fender mounting standard!
    Quote Originally Posted by farfromovin View Post
    You want the bike industry to come up with a standard?
    They've done a great job with bottom brackets, head sets, wheel spacing and seatposts....LOL
    I'd say that zip ties are the best standard there is!
  1. Surly Ogre Fender Mods/ALL FENDER MODS!!
    By Pynchonite in forum Bikepacking and Bike Expedition
    Last Post: 03-13-2015, 09:38 PM
  2. Question About Cascadia 29er Front Fender Mount
    By Mr. Ryan in forum Commuting
    Last Post: 12-15-2013, 10:00 PM
  3. Replies: 2
    Last Post: 12-26-2011, 01:19 PM
  4. Replies: 0
    Last Post: 03-10-2008, 12:13 AM
  5. Replies: 0
    Last Post: 03-09-2008, 11:53 PM
Members who have read this thread: 48
