Fox Transfer cable help- Mtbr.com
Results 1 to 6 of 6
    Aug 2010
    A ways back I bought a Fox Transfer from a local rider. It had a metal “barrel” taped to it which I believe I used to install the post. Soon after I hated the lever and removed the post until I could get a new lever.
    Now I have a Wolftooth lever and ordered a Shimano cable kit. The “barrel” on the new cable seems to fit the post just fine and makes me think the individual “barrel” that came with the post was for cables with a smaller barrel on the end. I’ve also watched some install videos and some mentioned using a “ferule” but I couldn’t really see what they meant in the video.
    Can I use just the cable that I have?
    If so, do I need to use a ferule as well?
    * Trying to post pics but doesn’t work.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    If it's like mine it uses a standard shifter cable and bushing or 'barrel'.
    Here's some deet's, even specific to Fox Transfer and Wolftooth.
    https://www.reddit.com/r/MTB/comment..._dropper_post/
    Reputation: Lone Rager's Avatar
    Dec 2013
    What Shimano cable kit did you get. Sounds like it might be a mtb brake cable if it has a transverse barrel on the end. The barrel (Fox calls it a bushing) is for shifter type cables with axial barrel ends. You should be using a shift cable and housing.
    What, me worry?
    Aug 2010
    Brake cable
    Aug 2010
    Think I can use the brake cable?
    It seems like it fits just like the Fox bushing would.
    No bueno. That barrel is putting all its pressure on the tip of the fingers. You don't want it to snap the fingers.
    Just use what you're supposed to use, shifter cable, shifter housing and the Fox barrel.
  1. Fox transfer post
    By Rick Draper in forum Components
    Last Post: 05-27-2020, 03:44 AM
  2. Replies: 12
    Last Post: 07-23-2018, 08:36 AM
  3. Replies: 7
    Last Post: 08-01-2016, 03:43 PM
  4. 2016 Fox Transfer dropper post
    By fixmefixmyhead in forum Classifieds
    Last Post: 06-25-2016, 05:08 AM
  5. Can you transfer a G2 crown to a new Fox fork to meke it G2?
    By BBBsti LTD in forum Shocks and Suspension
    Last Post: 01-19-2011, 04:47 PM
Members who have read this thread: 20
