External Routed Droppers- Mtbr.com
Results 1 to 13 of 13
    "That's what." -She
    Reputation: nathan_van's Avatar
    Jan 2019
    Ah yes, the seemingly never answered question, can I use an internally routed dropper post on an externally routed frame.
    I have a 2011 stumpy, and I have the original dropper post on there still, and it's days are quickly coming to an end. And with the snow finally melted off of the trails, I wanna ride.
    With new technology, internally routed droppers look nicer, and often times work much better than old, external ones. So, how can I put an internally routed dropper on my bike?
    Before you criticize someone, walk a mile in their shoes. That way you're a mile away, and you have their shoes too.
    Always in the wrong gear
    Reputation: Impetus's Avatar
    Aug 2014
    Drill a hole in your frame for the cable exit.
    ...donít do this.
    Shiftin' jumps and huckin' gears
    jcd's best friend
    Reputation: Battery's Avatar
    May 2016
    Quote Originally Posted by Impetus View Post
    ...donít do this.
    This
    ...don't do this.
    Trek …monda SL6 | Intense Recluse
    Big Mac
    Reputation: mbmb65's Avatar
    Quote Originally Posted by nathan_van View Post
    Really? Has this question been asked before, like many times, and never answered? How would you imagine this working?
    Apr 2015
    There are really good options for externally routed posts now. Check out the PNW components Cascade post or the Brand X Ascend II post. The cable actuates at the seal head, not the seat clamp, so the cable does't travel up and down with seat, and won't be a hazard to getting caught in your wheel.
    If you want internally routed, you'll need to drill a hole in your frame.
    ...don't do that.
    "That's what." -She
    Jan 2019
    That's my big problem is the mounting mechanism at the seat head. I will definitely take a look at those. Thanks a bunch!
    And I won't drill a hole in my frame. Cuz you guys did make it pretty clear...
    ...don't do that
    Self Appointed Judge&Jury
    Oct 2000
    Iím kinda in the same boat. Actually Iím just going to rebuild my old externally routed dropper.
    I was going to get a newer internally routed dropper and drill a hole in my frame for it.
    Nah, I wonít do that.
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    My old frame had external route for the seatpost, but I wanted an internal routed dropper... no, I didn't drilled my frame, I just routed the cable thru the BB.
    If you are using 1x and your frame used to be 3x with internal routing, check if you call route the dropper cable thru the BB.
    Aug 2016
    Why not wireless? My Magura Vyron works flawlessly.
    Bicycles don't have motors.
    Caca pasa
    Nov 2003
    And I won't drill a hole in my hole. Cuz you guys did make it pretty clear...
    ...don't do that
    Do whut.
    "합니다 행사에서 디비 판매 합니다 관련해" Lesleybien
    Hogan Lake blog. A section of Hogan Lake trails here.
    Gravity Dropper has made external routed for a long time. It is the most reliable dropper out there and easy to maintain yourself. If budget is an issue, check Pink bike for a used GD.
    Sent from my moto x4 using Tapatalk
    May 2019
    Love my brand X ascend II. Works flawless every time.
    Jul 2017
    Brand-X Ascend II is a good suggestion, value for money, and cable is attached at collar rather than the head.
  1. Replies: 13
    Last Post: 02-17-2019, 01:27 PM
  2. External routed dropper post ?
    By Craig/Fl in forum Components
    Last Post: 12-26-2018, 06:46 PM
  3. Which external routed dropper?
    By 1150A in forum Components
    Last Post: 10-15-2018, 03:54 PM
  4. Replies: 2
    Last Post: 05-05-2018, 07:09 PM
  5. Stealth Routed Droppers
    By beammescotty in forum All Mountain
    Last Post: 12-13-2014, 07:30 PM
Members who have read this thread: 54
