Extending shorter dropper post vs longer drop and slammed?- Mtbr.com
    Sep 2017
    Hey,
    I was curious about something regarding dropper posts in general. I'm 5'8" with a 31" inseam. I have a 2016 Santa Cruz 5010 (medium) which came with a 150mm Reverb. When it was time to switch posts I purchased a 150mm post in another brand (One Up).
    I haven't had any issues with it but recently had a pro bike fit done and was told I was losing power on climbs and top speed because I had my post too low. Now I've got the post up 30mm from being slammed and it's been working great and the fit is noticeably better actually.
    I'm curious if I should be looking to buy a 170mm or 180mm post now though that I can slam again to get the same overall height when fully extended.
    Is there really any difference between a 150mm post extended from the frame 30mm vs a 180mm post which would be slammed? (other than the seat being 30mm higher when slammed).
    Reputation: Timothy G. Parrish's Avatar
    Apr 2014
    Quote Originally Posted by mnpikey View Post
    Hey,
    A longer post may not fit your frame. You may want to check that first.
    Nov 2016
    I would say it depends. My 175mm post is 30mm from slammed on my enduro bike. The only time I notice it is if I am trying to suck the bike up to get it higher in the air. I have an XC bike coming with a 150mm so that will be interesting. If I have to buy another one for the big it will be 200mm though.
    Sent from my SM-N975U1 using Tapatalk
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Timothy G. Parrish View Post
    I suspect frame insertion will be an issue, too.
    I ride medium frames, too, and find that frame insertion is the bigger limiting factor than anything else with dropper fit. Both of my bikes could fit longer droppers if I could insert the posts deeper. I have to run less drop because of that reason.
  1. Replies: 29
    Last Post: 2 Weeks Ago, 06:54 PM
  2. slammed height of dropper posts - Blur LTC?
    By RTM in forum Santa Cruz
    Last Post: 08-23-2014, 08:47 PM
  3. Replies: 34
    Last Post: 06-30-2013, 09:24 AM
  4. Shorter and shorter CS's = too unstable??
    By A Grove in forum Urban/DJ/Park
    Last Post: 02-25-2008, 06:33 PM
  5. Replies: 5
    Last Post: 04-06-2007, 11:30 AM
Members who have read this thread: 26
