Entry level air fork suspension suggestions- Mtbr.com
Results 1 to 2 of 2
    Aug 2016
    Hi All, Can anyone suggest an entry level air fork to replace this one on my hybrid bike?
    Suntour NRX D HLO. 63mm. Hydraulic Speed Lockout / Preload
    https://www.srsuntour-cycling.com/pr...RX-D-5895.html
    I won't be doing anything extreme with it. I'd like to have a stiff adjustable suspension that will mostly be used for smoothing out the bumps on the road and gravel trails.
    This is my current bike:
    https://www.bikes.com/en/bikes/whistler/2015 (Must select Whistler 70 when on the site)
    Maxxis cult follower
    Reputation: richj8990's Avatar
    Apr 2017
    Quote Originally Posted by kovacsa View Post
    This should probably be moved either to the shocks and suspension forum or the gravel bike forum. The problem with your situation is that most forks now, even the older 9mm x 100mm quick-release ones, are 100-120mm or more, there are not even many 80mm travel ones especially for a 29" bike. There are 80mm ones still sitting around, waiting to be purchased for 24" or 26" bikes but I don't think there are any for 29" bikes, so you may have to get the same exact fork again. Try posting this in the gravel bike forum, they will know more about it. Remember that you need a fork that is 9/100mm for fitting the right axle, and 1 1/8 straight steerer, and I would not go over 80mm, 100mm is probably too much.
    We ALL have something to learn here. Post helpful solutions instead of flaming for your own sadistic need.
  1. 2013 Mid-level bike or 2018 Entry-level bike?
    By kepler364 in forum Beginner's Corner
    Last Post: 09-04-2017, 09:45 AM
  2. Coil vs air fork for entry-level hardtail
    By Endoismynamo in forum Shocks and Suspension
    Last Post: 07-31-2016, 06:55 PM
  3. Entry level vs Mid Level Full Suspension?
    By latemp in forum All Mountain
    Last Post: 12-24-2015, 06:41 AM
  4. Lowest Level of components for an entry level bike?
    By herder in forum Beginner's Corner
    Last Post: 04-14-2015, 08:42 AM
  5. Replies: 50
    Last Post: 05-08-2014, 12:33 PM
Members who have read this thread: 24
