Is this dropper serviceable? Can't remove bottom cap.- Mtbr.com
    Oct 2011
    Hello,
    I have what I believe is a TranzX YSP03 dropper (however is not marked as such). It came stock on a 2017 specialized ruze (womens' version of the fuse).
    I assumed that it would open like most TranzX/cartridge-based dropper posts, that unscrew at the seal and the bottom cap. However, the bottom cap is not unscrewing, even with a good amount of force. It seems like it has a membrane around it (see pictures). Could it be press-fit? I'm scared to apply too much force.
    Thanks.
    Is this dropper serviceable? Can't remove bottom cap.-img_20200715_143213.jpg
    Photo upload is not working for me, but there are some more pictures here: https://imgur.com/a/9OWjdHg
    Oct 2011
    Update: case closed. Just scary amounts of brute force was all that was needed.
    Some kind of super strong dried loctite on all the threads.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    use a heat gun on threads like that on shocks/forks/droppers it'll loosen it right up
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Oct 2011
    Quote Originally Posted by 127.0.0.1 View Post
    Good idea, thanks. I'll add it to the arsenal.
  1. Replies: 13
    Last Post: 12-21-2015, 06:38 PM
  2. Dismantling (serviceable) ISIS bottom bracket?
    By Palych in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-25-2008, 10:56 AM
  3. Replies: 9
    Last Post: 05-08-2008, 12:02 AM
  4. Can't remove Boxxer Team spring top cap...
    By pin-it in forum Downhill - Freeride
    Last Post: 07-12-2007, 09:13 PM
  5. cartridge bottom brackets none serviceable?
    By crgowo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-15-2005, 09:21 AM
Members who have read this thread: 40
